engine is running rough
Old Jan 16, 2010 | 01:51 PM
amikesell's Avatar
Just as the title says, my engine is running rough. This problem started after I had my thermostat go bad on me. I ran the coolant temp up to 240 once and that was when I first noticed it was overheating, after that i shut it down and had some guys from work tow me in. I fixed the problem that night but noticed it was idling rough with a slight lope to it at an idle and running down the road it just doesnt sound right. I checked my LP pressure and I have 15 PSI@Idle and 10 PSI@WOT without my smarty, with the smarty set on "fuel saver" i still have the 15 PSI@Idle but my pressure drops down to 7 PSI@WOT and I checked it with a 3/8" fuel line, I also changed out both fuel filters about 4500 miles ago. I am also on my original vp44 with just over 200,000 miles.
I am just wondering where to start looking or if someone else has had this problem and corrected it. I apperciate any and all help, thanks.
Old Jan 16, 2010 | 04:57 PM
sheriffav8r's Avatar
VP-44 electronics fried? Any codes?
Old Jan 16, 2010 | 07:38 PM
amikesell's Avatar
The only codes I get are when i have the smarty downloaded but as far as on the stock setting I have got nothing. But i did get a poor performance due to engine overheat code and haqs not came back since the new thermostat. I might get my injectors pop tested and do a compression test on the engine while they are out.
Nonicpower
Aug 10, 2014 07:44 PM
builtnotbought1
Jul 6, 2014 09:49 PM
BIGBIRD
Apr 10, 2007 01:00 AM
JR Parker
Apr 14, 2004 05:42 PM
Hummin Cummins
Oct 29, 2003 07:19 PM
