Engine misfiring under accel...
Old Oct 19, 2004 | 07:36 PM
honda318dx's Avatar
I've been reading the forum for awile, but this is my first post and first question. I also searched and didn't find any info I could use.
Here is what is going on. The truck is a 2000 3500 2wd DRW 5 speed, with 150k on it.
Anyways, a couple months ago, the truck would "misfire" trying to accel from left and turns. Yes, very odd. Now, its doing it more often, now turning right with accel, going straight with hard accel, or even hitting a large dip in the road.. It just seems like the motor isn't getting fuel for a split second, then comes right back to life.. This is getting very annoying when pulling my trailer, so I'm asking you guys for help. I am an avid do it yourselfer, so enlighten me please
Thanks for the help
Corey
Old Oct 19, 2004 | 08:51 PM
Copenhagenjunkie's Avatar
Welcome Corey,
No matter how "strange or odd" with any fuel type symptom start by checking fuel pressure. With your miles it may be the lift pump.
Karl
Old Oct 20, 2004 | 09:08 AM
honda318dx's Avatar
I wouldn't "think" it would be fuel pressure, because once it does this inital hickup, it will pull all the way through the powerband fine.. Not argueing, just trying to figure it out.. Maybe I just have a buildup of water, I havn't drained it in awile..
Old Oct 20, 2004 | 03:46 PM
futch's Avatar
You need to drain water on these motors? Why?
Thanks.
Old Oct 20, 2004 | 06:18 PM
BigBlue's Avatar
Diesel fuel has a little bit of water in it (that's one of the reason's it gels in the cold) and water is bad stuff. In 72K miles, I've drained maybe a 1/4 cup out. MAYBE.
Check your codes. Is the truck hard to start after it's warmed up? Do you have a dead pedal? If you get a P0216, that means your injection pump is shot. Check your fuel pressure and get back to us on that.
Old Oct 21, 2004 | 11:56 AM
gandrews's Avatar
Two thoughts:
1 - From reading here - I have read about problems with the fuel pickup in the tank. The problem you describe may be from that - Is there any difference if the tank is full or not? Do you have a fuel pressure gauge? If so what does it tell you?
2 - Do you have the pump wire tapped? I had a Banks Ottomind box. About a year ago upon hard accelleration (getting on the freeway etc.) the truck would miss - skip a beat or two. Anyway it turned out to be the ground for the Banks Ottomind. Ran the ground wire to a negative cable and that particular problem went away.
I would also check the codes as Bigblue has suggested.
Good luck
George
Old Oct 24, 2004 | 02:31 AM
hauliday's Avatar
first and the most easy thing to check is the fuel filter
Old Oct 24, 2004 | 11:20 PM
SuperDave4x4's Avatar
My truck did the exact same thing and i had to replace the lift pump.
Old Oct 25, 2004 | 11:43 AM
honda318dx's Avatar
Cost? Did you replace it with a Dodge part or aftermartket..
Old Oct 25, 2004 | 05:54 PM
BigBlue's Avatar
From cummins, it costs about $150. It's covered under the extended warranty.
Old Oct 26, 2004 | 12:13 AM
kixnbux's Avatar
Would the lift pump cause this kind of "sputtering" while only under load?
My 2000 6spd 2500 cummins recently started the "sputtering/hesitance" when under acceleration or climbing even small hills. It is absolutely only when under load though, I can run the rpms idle and up to 2500 with not even a hint of a "sputter" when not in gear, but in gear it sputters through the powering, and is even more obvious on a hill.
No Check Engine Light at all.
Old Oct 26, 2004 | 03:56 AM
AlpineRAM's Avatar
Insufficient fuel supply on a diesel will only be notable when you need horsepower. To rev the engine at idle it won't need many hp, climbing a hill or accelerating will need hp.
You can say that horsepower=gallons/hour
So check your fuel pressure under load!- The FP at idle is not really significant.
AlpineRAM
Old Mar 29, 2020 | 07:20 PM
Spencer Martin's Avatar
Truck probs
exactly what mine is doing
Old Apr 1, 2020 | 11:06 AM
jrs_dodge_diesel's Avatar
Welcome to DTR
Better to start your own thread with your trucks issue instead of bring up one from 16 years ago.
kjw
Jan 18, 2009 09:22 PM
Katmandu
Nov 15, 2008 11:21 PM
usmcduncan001
Sep 24, 2007 07:03 AM
ataboy9026
May 13, 2007 11:15 AM
98 2500
Mar 5, 2005 02:06 PM
