EGT's are getting higher
Old Jun 10, 2008 | 04:38 PM
  #31
AggieJustin's Avatar
Any leaks on any of the intake side connections? What are you using the disable the wastegate on the HX35?
A dirty intercooler could cause higher temps, but not lower boost numbers. If you have still have the blowby bottle up front that isn't regularly cleaned, you may be getting a film of oil on the intercooler and rad fins that is holding dirt and preventing proper cooling.
Old Jun 10, 2008 | 04:45 PM
  #32
mopar440cu's Avatar
I have an elbow on the turbo that has a set screw to adjust, or close the waste gate. I had the front torn apart to check the radiator and its not plugged. I wish that was the answer!!
Old Jun 10, 2008 | 05:10 PM
  #33
Any change to overall boost if you close the elbow more than it is now?
Old Jun 10, 2008 | 06:00 PM
  #34
mopar440cu's Avatar
It is completely closed now.. I tried it with it partial open and the spool up was horrible!
streetsmoker
Aug 9, 2006 05:55 PM
t_george77
Nov 23, 2005 02:19 PM
jerry007
Oct 28, 2004 08:24 AM
tobyw
Sep 16, 2004 10:07 AM
DaNuGuy
Jul 6, 2004 08:37 PM
