ECU / oil pressure problem.
Old Apr 10, 2013 | 11:49 AM
Redlinear's Avatar
I have an ECU that was removed from a 2002 truck. Truck was wrecked, but, it ran fine and held good oil pressure.
Sold the ECU and the customer says his truck now runs great, but, he has no oil pressure showing on the gauge.
I'm simply curious as to "why"?
Best I can remember, all, or some, 02 model trucks use an oil pressure sending unit that is "different".
It's much like a dummy light switch and won't work a gauge. (yea? nay?)
Where-as a sending unit off of an 01 will control a gauge. (yea? nay?)
Does any of this make sense?
What am I running into here?
Just a bad ECU, or, A good ECU being installed in the wrong environment?
Old Apr 11, 2013 | 12:46 PM
jrs_dodge_diesel's Avatar
Depends on what what in the truck that the ECU came from.
If the engine had the pressure switch, then the ECU was programmed for that. However, if the engine had the pressure sensor (like my 2001.5 has), then the ECU will be looking for a sensor.
The pressure sensor has three wires and costs about $90 at a Cummins shop. The pressure switch has either one or two wires (don't remember which), and is a lot cheaper.
Hope this helps.
Old Apr 11, 2013 | 07:13 PM
Redlinear's Avatar
Thanks!
That is "sort of" what I was thinking, but....
I was wondering if an ecu off of a "sensor" truck had nothing to do with the gauge.
And an ecu off of a "switch" truck had everything to do with the gauge.
Old Apr 11, 2013 | 08:03 PM
jaconst's Avatar
Hey redlinear have another ECU?
Old Apr 11, 2013 | 09:29 PM
My mistake.
It is not the ECM that monitors oil pressure (at least not for the guage). It is the PCM.
From the service manual:
The oil pressure gauge gives an indication to the
vehicle operator of the engine oil pressure. This
gauge is controlled by the instrument cluster circuit
board based upon the cluster programming and electronic
messages received by the cluster from the
Powertrain Control Module (PCM) over the Chrysler
Collision Detection (CCD) data bus.
The PCM continually monitors the engine oil pressure
sensor to determine the engine oil pressure. The
PCM then sends the proper engine oil pressure messages
to the instrument cluster.
The service manual indicates that this is the same for gas and diesel Rams.
Bushmaster
Jan 4, 2011 08:05 PM
Muzzy
Dec 13, 2004 07:36 PM
roadrat
Jan 18, 2004 03:07 PM
