Drain plug 47re
Old Feb 20, 2012 | 10:09 AM
travelingman's Avatar
Question Drain plug 47re
Have any of you installed a drain plug on your trans pan ? If so is there anything in paticular to be known or careful of or a specific type to buy ? I'm installing a new trans an after drowning myself last night I thought now would be the time to cure this proublem . I'm looking at one from NAPA .
Old Feb 21, 2012 | 07:09 PM
rickf's Avatar
I usually drill a 3/8 hole in the pan and then weld a 3/8 nut over it. Take the 3/8 bolt and slide a snug O-ring over the bolt and tighten it snug but not so tight you squeeze out the o-ring. You could also use a nylon washer instead of the o-ring and then tighten the bolt tighter.
Rick
Old Feb 21, 2012 | 07:11 PM
hamilton71801's Avatar
My Mag-Tec has one.
Sent from my iPhone using Tapatalk
Old Feb 22, 2012 | 09:18 PM
bcbigfoot's Avatar
I drill a hole in the pan, hacksaw a 1/4 inche pipe threaded cast iron coupleing in half, then braze it over top of the hole.
B+M has a kit for installing a drain plug but it has a tendancy to leak.
thehemikid
Feb 25, 2021 12:45 PM
klx650a2
Jan 10, 2008 12:08 AM
Munchies
Oct 19, 2006 06:09 AM
Ram44maR
Jul 22, 2005 08:10 AM
wooff
May 1, 2003 11:22 AM
