Dodge down, need help
Old Jun 19, 2011 | 03:20 PM
hdguage's Avatar
I have a 2000 dodge 2500 and was driving down the road and it just stalled and would not restart. it has 18psi fuel pressure. Any one had this problem before ? Any and all help is welcomed. Thanks
Old Jun 19, 2011 | 03:52 PM
New2Diesel's Avatar
"Gomer Pyle"
The only time this has ever happened to me is when a fuel pump went out or my pump crapped out on me.
Old Jun 19, 2011 | 08:18 PM
dkenny's Avatar
an air leak can cause this. do you check for leaks and/or try priming the system. do you have at least 1/4 of a tank of fuel?
-dkenny
Old Jun 19, 2011 | 08:40 PM
hdguage's Avatar
I have over a 1/4 tank of fuel. Are you refering to leaks in the supply line from the tank ?
Old Jun 19, 2011 | 08:53 PM
whiskers's Avatar
It's easy to check the lift pump. Just open the water drain valve on the fuel filter and turn the key to bump start twice and leave it on. it will run the fuel pump for 30 mseconds. if you are getting fuel out the drain pipe, you have a VP pump problem.
Old Jun 19, 2011 | 09:08 PM
banzaitoyota's Avatar
Got any codes?
Old Jun 19, 2011 | 09:30 PM
Tallguy67's Avatar
Hmm , I just thought of something. There are a bunch of posts about our trucks having faulty sending units for fuel level in the tank. Before you check the tough stuff, why not dump a few gallons of diesel in from a jery can. It would suck to do a lot of work just to find out you were out of fuel.
Old Jun 19, 2011 | 11:25 PM
johnh's Avatar
he said he had 18 psi fuel pressure
Old Jun 20, 2011 | 06:13 AM
dkenny's Avatar
I think you can still get 18psi of 'fuel pressure' if you have air in the system.
yes you might a leak in the supply lines. not sure what fuel pump you have but check lines from the tank to the pump.
-dkenny
Old Jun 20, 2011 | 08:16 AM
hdguage's Avatar
I have a Fass lift pump. I thought of the faulty sender and dumped 5 gal of fuel in it. I'm checking the lines for a suction leak before the pump. Is there a way to check the VP to see if it is ok ?
Old Jun 20, 2011 | 10:15 AM
hdguage's Avatar
Turns out that I had a faulty sender in the tank. Once I bled the air out of the system it started right up ! Thanks for all of the help.
Old Jun 20, 2011 | 04:51 PM
dkenny's Avatar
good news..glad to hear you got it running again.
-dkenny
Old Jun 20, 2011 | 09:22 PM
Tallguy67's Avatar
Dang - and I was ready to apologize all day today for being stupid. Even a blind squirrel finds a nut now and then. Glad it was a cheap and easy fix.
Gerbil
Apr 20, 2011 03:42 PM
DAN POUCHER
Jun 14, 2008 06:52 PM
DAN POUCHER
May 7, 2008 07:23 AM
CORed
Sep 20, 2006 08:25 PM
