Died AGAIN
Old Oct 31, 2009 | 12:33 PM
Shovelhead's Avatar
Administrator / Scooter Bum
When you replaced the batteries, did you reset the APPS?
That could be the reason for the non-responsive thottle.
APPS reset procedure
Old Oct 31, 2009 | 03:18 PM
Rocky5.9's Avatar
Thanks, Shovelhead... I followed your link and did the APPS sensor reset. No change.
Which of the pumps does the throttle control?
This is really irritating...I know the Cummins ISL 450 inside and out but can't seem to solve my own problem...
Old Oct 31, 2009 | 04:12 PM
Shovelhead's Avatar
When you step on the throttle, the pedal is connected via cable to the APPS (mounted to the bracket above the injection pump) which sends a signal the the injection pump, controlling the fuel delivery, and ultimately the RPM.
Old Oct 31, 2009 | 08:09 PM
slowflyer2112's Avatar
If you open the valve on the fuel filter to drain the water out and hold the hose up a little then turn on the key to start, fuel should run out if it doesn't. You need a new lift pump. good luck
It sounds like you need a new injection pump.
Old Oct 31, 2009 | 11:49 PM
nickg's Avatar
Originally Posted by Rocky5.9
I just replaced both batteries...the truck starts but has a really low and rough idle and a dead throttle. The odometer code I pulled up is p1693.
As far as voltage I have plenty of battery and the alternator is good. What I'm not sure of is the voltage regulator fixed to the alternator?
alt is controlled by PCM.
1693 means you have codes in the ecm/pcm, you need to have them pulled. a failed LP could starve the IP, causing low idle and no throttle response
heres a good read on VP diagnosis
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Nov 2, 2009 | 05:54 PM
Rocky5.9's Avatar
I did a google search on the APPS Sensor. This is what I found. Is there much truth to this? http://www.cumminsforum.com/articles...ing/Page1.html
Old Nov 2, 2009 | 06:03 PM
Copenhagenjunkie's Avatar
Yes, that is the Apps recalibration method. I have done it many times.
Old Nov 3, 2009 | 07:43 PM
Rocky5.9's Avatar
I recalibrated the APPS Sensor...it was at .71 VDC when I started...the tag on the sensor said it needed to be .554 VDC. The whole process was not very difficult, however, I do want to note that the movement it takes to adjust the voltage is ever so slight. If anyone attempts this procudure be sure to recheck the voltage after tightening the APPS and throttle quadrant to be sure the sensor did not shift.
I also had a friend help with the procedure and testing the LP as mentioned above. There is no change in my situation, other than I know the APPS Sensor is calibrated to the correct value, and there is no audible noise from the LP, or fuel coming from the drain tube when the ignition is in the ON position and the the fuel filter lever is opened.
Tomorrow I will buy a Lift Pump...if the Injector Pump is the problem in the long run, I will be losing $200 for preventative maintenance.
All and any other ideas are welcome and appreciated.
Old Nov 3, 2009 | 08:40 PM
nickg's Avatar
In case you dont know the LP only fires for a second when you just turn the key on, it will run for 20sec or so if you "bump" the starter and even if you turn the ignition back off it will still run for 10-20seconds after the starter was "bumped"
Old Nov 3, 2009 | 08:54 PM
Rocky5.9's Avatar
Yes I was under the hood while the key was turned.
Steven K
Jun 4, 2009 10:32 AM
Firemanhoser
Dec 13, 2007 01:05 PM
SilverSootXpres
Apr 15, 2007 09:28 PM
b84u
Feb 20, 2006 01:04 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
