Did some some 2500s come with factory lockers?
Old Jul 17, 2007 | 07:48 PM
wrangler04's Avatar
I was driving around in the parking lot messing with my 4wd and when ever it was engaged going around corners the tire would slip just like a locker. Is it supposed to do this? Ive own a Jeep with a locker and is almost exactly the same. Does anyone know anything about factory lockers.
Old Jul 17, 2007 | 08:01 PM
realtreehunter's Avatar
im pretty sure the fronts are fully locked and the rears had the limited slip option but i could be wrong
Old Jul 17, 2007 | 08:03 PM
wrangler04's Avatar
well mine is a 99' and it feel alot more than a limited slip, the tires chirp a little.
Old Jul 17, 2007 | 10:09 PM
duffer26's Avatar
in 4wd in a parking lot it is the front tires trying to turn at a dif rate than the rear ...and one hell of a good way to break something you have to much traction on a paved surface for 4wd and it will look for the weakest point to let all that bound up pressure out like pinion, Axel, u-joint, t-case, and so on so forth the jeep weighs allot less than these trucks and is essayer for it to slip a tire than these trucks
Tuf-4x4
May 3, 2009 08:23 PM
airplaneman00
Sep 29, 2007 10:16 AM
onemoretruck
Sep 25, 2006 07:32 AM
HOHN
16
Dec 17, 2003 10:38 AM
2001CamaroSS
21
Dec 13, 2003 09:32 PM
