dead pedal
Old Oct 3, 2007 | 12:14 PM
skindaddy's Avatar
dead pedal
my buddy has a '98 24v and the pedal will go dead so he shuts it off turns back on works for awhile,just replaced lift pump (somebodys idea) still problem thinkin probably tps what your thoughts? will a 98 show codes?
Old Oct 3, 2007 | 01:59 PM
nmen's Avatar
Check the filter. Sounds like a demand or high flow problem.
Check the fuel flow at the VP44. It should have a "healthy" stream of fuel into a coffee can with the lift pump running.
Of course the TPS (APPS?) could be sending only 1/2 the signal voltage at WOT. I don't know the 98 models.
Lastly, a dead pedal syndrome may be a dreaded IP failure, but you can do your search on this forum for that.
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
BillH
Apr 26, 2004 10:09 PM
mymaur
Jan 26, 2004 11:31 AM
