Dead pedal?
Old Feb 9, 2007 | 08:51 PM
silversmoker's Avatar
Dead pedal?
I have an 02 4x4 6 spd. and about 50% of the time now I am getting the dead pedal. I can put the pedal to the floor and the truck just won't go. Any suggestions to what this may be?
Thanks,
Ryan
Old Feb 9, 2007 | 08:54 PM
edy's Avatar
edy
get out your check book sound like the vp44 i would check your dtc's
Old Feb 9, 2007 | 08:58 PM
I just had a new one put in about 10k ago and I have the fass and have never put less than 14 psi through it.
Old Feb 9, 2007 | 08:59 PM
Oh and I have no codes! Even checked them with the smarty.
Old Feb 9, 2007 | 09:01 PM
hump's Avatar
Thumbs down silversmoker
Sounds like the injection pump is going out on ya....A friend of mine just went through that whole deal with his 2001. His truck had the exact same symptoms.......dead pedal!! He ended up getting a new lift pump & injection pump under warranty. Took care of the problem
HUMP
Old Feb 9, 2007 | 09:02 PM
Yeah matbe so. I have only 93k on it so I will let the waranty take care of it.
Old Feb 11, 2007 | 04:06 PM
I really don't see this being the vp, is there anything thing else it might could be? I'm not getting hard starts or anything other than the fact that my fuel pressure has dropped about 3 psi.
Old Feb 11, 2007 | 04:11 PM
team's Avatar
unplug any fueling boxes, boost foolers etc. first and see if it still does it. I had a boost fooler that was causing my problems. When i took it off, no more dead pedal.
Old Feb 11, 2007 | 06:03 PM
brockdieseldude's Avatar
Check the APPS sensor that is one of the main causes of the dead pedal the only problem with checking it is you need a scan tool to see the percentage of the APPS when you push the go pedal. It hardly ever sets a code.
Old Feb 15, 2007 | 11:59 PM
I have a buddy that knows how to do so I will let him do that. We will see what that does.
Thanks,
Ryan
600 Megawatts
Mar 26, 2008 07:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
BillH
Apr 26, 2004 10:09 PM
mymaur
Jan 26, 2004 11:31 AM
