Dead LP
Old Feb 20, 2010 | 02:52 PM
rbuchana's Avatar
Dead LP
Driving along today, and I got a dead pedal, then a puff of gray smoke and then dead. It wouldn't start after crank.
I towed it home & put a fuel pressure gauge on the Schrader valve on the VP44. It had 0 PSI during crank.
It throws codes P0500, P0234 & P1693.
So is it the VP44 or the LP?
Old Feb 20, 2010 | 06:51 PM
diggerfan99's Avatar
There is a spot on top of your Fuel filter housing for a pressure check. Its just a plug, then check pressure there because that would be before your VP-44. IF there is no pressure there, your LP is dead. Hopefully, it didn't damage the VP-44. Good luck.
Old Feb 20, 2010 | 06:58 PM
rbuchana's Avatar
What was I measuring on the Schrade value just below the VP?
Old Feb 20, 2010 | 07:14 PM
scottsjeeprolet's Avatar
Unlike the 99 the 02's don't have the same filter housing. Measuring it at the Schrader valve is a good place.
Look at either replacing the LP or going aftermarket. Even if you VP is dead you'll need a new supply pump. Airdog is very good.
Old Feb 21, 2010 | 04:19 AM
rbuchana's Avatar
So if I measure 0 psi during crank at the Schrader value, does that indicate an LP problem? Or at least something other than the IP?
Old Feb 21, 2010 | 07:30 AM
Bump the starter with the key and listen for the pump. It should run for 30 seconds. The pump doesn't run while cranking.
Old Feb 21, 2010 | 08:59 AM
nickg's Avatar
read this to help diagnoise
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Feb 21, 2010 | 10:11 AM
sheriffav8r's Avatar
You can also loosen an injector line at the block and bump the starter. It should bleed fuel after a couple of times doing that. A fuel pressure gauge is a must, though. I have a cheapo mechanical one from Northern Tool (oil pressure gauge 0-30psi) that I tap after the boost pump (relocated to the frame rail). I can lean down and check it under my truck if there is any doubt. I also have the Edge Juice w/ Attitude which is great....
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
