Dead LP
Old Jan 18, 2007 | 09:14 PM
Adam F's Avatar
Dead LP
My lift pump died AGAIN on the way home from work,I want to use a holley blue but I'm not sure if I need to run it with the stock lp or if it would be ok alone?
Old Jan 18, 2007 | 09:36 PM
Geico266's Avatar
Loose the stock LP.
Old Jan 19, 2007 | 08:14 AM
CTDboy's Avatar
I agree, espcially if your lift pump is already dead. It will just be a restriction in the fuel line. Boo to stock pumps.
Old Jan 19, 2007 | 02:36 PM
Adam F's Avatar
I ment if I get a new LP,lol, should I use it with the blue or just forget about the LP and just use the blue?
Old Jan 19, 2007 | 03:29 PM
Doug_TX's Avatar
Just use the Blue without the stocker. Don't use the regulator that a lot of places sell with the pump. Do you have the engine mounted or the in tank LP? If you have the in tank version you might need a draw straw.
Old Jan 19, 2007 | 08:24 PM
TNfarmboy's Avatar
What ever you do, forget the stock set-up
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
