dead dodge
Old May 26, 2013 | 09:32 PM
bellclan's Avatar
found the #3 fuse looks good, but not sure
Old May 27, 2013 | 07:12 AM
Busboy's Avatar
As was already mentioned just check your fuel pressure at the schrader valve on the VP, just "bump" the starter and the pump should run for 25 seconds, no pressure then it doesn't matter if the pump is running or not if it's not pumping fuel. If you don't have a gauge then you could take the line off and see if the pump is delivering fuel, I forget how much it's supposed to deliver in one minute. Are you certain the pump is in the tank and not on the side of the engine block???
Old May 27, 2013 | 02:31 PM
bellclan's Avatar
Lary was right, out of fuel, running now, thanks for all the help, run out of fuel with just under a qtr tank, will fill up now at half tank, thanks again keep on trucking
Old May 28, 2013 | 01:30 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Use your trip meter by zeroing it at every fill up then fuel up again according to mileage...don't trust that sender at all I have seen them show half tank and be dry
Old May 29, 2013 | 07:58 PM
nothingbutdarts's Avatar
Great news!
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
