Cruise Control And Airbag Light
Old Jul 5, 2005 | 08:30 PM
99NVRam2500's Avatar
Ok, I had a leaking steering gear box, so I replaced it. Now the AIRBAG light is on and the cruise is inop. Now, sure, I pressure washed the truck engine compartment and the under carriage. Where do I start looking at? All fuses APPEAR to be good. Thanks.
Old Jul 5, 2005 | 08:34 PM
phox_mulder's Avatar
Has there been time for everything to dry under the hood?
Why this would affect the airbag, unless you got water in the PDC
(big plastic box with fuses, relays and such in it).
For the cruise, there is a box under the driver side battery hooked to vaccum, often the line comes loose, or battery acid drips down on them compromising their integrity.
On edit, where is the airbag sensor on a 99?
Mine has the momentum switch in the cab,
but maybe the 99's had them in the front end, behind the headlights maybe?
phox
Old Jul 5, 2005 | 08:36 PM
I washed up there pretty vigorously. the cruise light doesnt even come on. I will check it though.
Old Jul 7, 2005 | 03:37 PM
Saxet Nomad's Avatar
A couple of people I knew had the problem w/ cruise and the air bags...come to find out there was a plug coming loose in the steering column when they pegged out the steering wheel one way...maybe your steering wheel moved more when you had the steering box off???
Old Jul 9, 2005 | 06:22 AM
Valv's Avatar
Watch your clockspring....
I replaced my gearbox and turned steering too much one way and broke it.
Old Jul 9, 2005 | 07:57 AM
jrs_dodge_diesel's Avatar
That was my thought too. Broken clockspring would definitly affect both.
Old Aug 3, 2005 | 04:08 PM
How hard is it to change this? and does both the Airbag and Cruise Control run through this?
Old Aug 4, 2005 | 04:51 PM
I think you have to pop the wheel off (disconnect the air bag first !!!). The clockspring is there to supply the voltages to the moving airbag and button when you turn the wheel.
Old Aug 16, 2005 | 08:04 PM
Not to hard to fix, and having CRUISE back, A HUGE plus. Took all of about 20 minutes.
Old Aug 16, 2005 | 10:04 PM
How hard is it and whats involved? Glad you got it fixed.
Old Aug 17, 2005 | 03:42 AM
1. buy clockspring
2. remove 3 torx screws from steering column cover
3. remove 2 8 mm bolts from air bag.
4. remove wires from airbag, take time to figure out locking system for wires
5. remove steering wheel.
6. unplug long wire running down steering colum.
7. unplug remaining wires from clockspring.
8. wiggle locks loose on clockspring.
9. remove clockspring.
10. re-install clockspring and revere steps.
EdmontonCanada
May 8, 2014 10:21 PM
csramsey640
Jan 5, 2011 08:14 PM
csramsey640
Jan 5, 2011 07:37 PM
12vkaleb
Dec 31, 2009 08:03 PM
yodey44
Aug 30, 2007 07:15 PM
