ABS Brake Light, Cruise Control and Overdrive
Old Aug 14, 2007 | 05:16 PM
yodey44's Avatar
Hi,
1994 Dodge 2500 Ram Diesel 4 wheel drive.
I was in a bad rainstorm a few weeks ago, my abs and brake light came on.
I thought something may have got wet. It's been a few weeks (plenty of time to dry out.) It comes on when the truck is idling but when I rev the motor it goes off. I checked all the fuses etc. even unhooked the batteries.
I took it to my mechanic to have him check it out and he put it on the scanner and he said the abs sensor is bad and they cost $250. He said I didn't need it if I didn't want to spend the money. Well my cruise control quit working also, so I bought the $12 brake pedal switch but that didn't work either. I think the overdrive isn't working also? Could it be a vacuum leak? The mechanic said he checked the vacuum and it was fine. Speedometer works fine.
Old Aug 14, 2007 | 08:26 PM
sschil3's Avatar
I had the same problem with my '03 (only after rainstorms). Took it in to the dealer (warranty you know) and they told me it was the APPS. They changed it and the problem did not go away. Took it back and they said it was the ECM. They changed that. Still didn't go away. I finally took the connectors to the ECM off myself, cleaned them and covered with electrical grease. Problem hasn't come back and that was 60,000 miles ago.
Old Aug 30, 2007 | 07:15 PM
yodey44's Avatar
Hey, Hey,
Mechanic replaced the brake switch, cleaned all the wire connections and put electric grease on them. Everything is working great so far.
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
fschiola
Oct 9, 2004 11:31 AM
