Cover on the front of the engine......
Old Aug 15, 2005 | 07:25 PM
storx's Avatar
i ahve noticed there is a little build up o oil on the the front of the cover on the front of the engine....
Old Aug 15, 2005 | 08:20 PM
P.J's Avatar
P.J
It's your breather bottle (aka puke bottle) I think it acts like a PCV.
Should have a "J" shaped tube attached?
Remove the bottle and clean it out, or look up the relocation instructions.
Old Aug 15, 2005 | 08:31 PM
P.J's Avatar
P.J
Unless your talking about somewhere else?
Is it like a coating all over your Power Steering pump?
Old Aug 15, 2005 | 08:38 PM
Mopar1973man's Avatar
I think storx is talking about the puke bottle...
If so check out my pic gallery for a fix to this problem... Custom vent pipe.
If not... Then you must be talking about the vacuum pump seals... Never had to do one but I know there are several that can help you out...
Old Aug 15, 2005 | 08:45 PM
storx's Avatar
alright i took off the tube going to the bottle and the bottle was filled to the very top..........whats with this thing?........it vents that much oil?.........
Old Aug 15, 2005 | 09:03 PM
phox_mulder's Avatar
It is supposed to be emptied at every oil change.
If you haven't been taking it to the Dealership for oil changes, it probably has never been emptied.
Heck, even some Dealerships don't know they are supposed to empty it.
phox
Old Aug 15, 2005 | 09:06 PM
That's why some of us relocate the puke bottle...
If you do any 4x4 you will loose a lot of oil out the puke bottle... That is why I went over the back of the engine.
There is more pic in the gallery of this BOMB...
Old Aug 15, 2005 | 09:35 PM
storx's Avatar
well...i had no clue... and i tryed to empty it but half the bottle the oil is so thick it dont wanna come out im going to fill the bottle with degreaser and let it sit over night
Old Aug 15, 2005 | 10:00 PM
fschiola's Avatar
You might want to think about relocating it. If you look close you will probably see oil coating your fan and the back of the radiator as well.
Old Aug 16, 2005 | 12:19 PM
shawn085's Avatar
I have read all kinds of stuff about this puke bottle but I have yet to see it on my truck. Did some trucks not get built without it or has mine been modifyed by dodge? It has a hose pointing backwards down by the frame as the vent (no bottle) and it looks like it vents from the back of the engine no the front.
Old Aug 16, 2005 | 02:44 PM
Joe Diesel's Avatar
I empited my after a year and it barley had any oil in it, probably cause its all over my engine but i like that oil there it acts has a rust coating up here in salt territory
Old Aug 16, 2005 | 05:31 PM
Dodge does have a TSB that relocates it.
If the truck goes offroad and down steep hills, the oil can come out, damaging the engine.
The TSB relocates it to the rear of th engine.
Either that TSB has been done, or maybe the previous owner moved it?
(assuming you aren't the original owner)
phox
Old Aug 16, 2005 | 07:40 PM
Tayloe08's Avatar
Did anyone secure the pipe anywhere or just lay it over the engine. Does the main piece along the valve cover need to slope toward the back of the truck or will the oil make it through on its own?? Thanks
Old Aug 17, 2005 | 07:49 AM
Mine just lays on top of the manifold. Trust me the oil makes to the other end just fine... If your using rubber hose beware that the rubber will break down and kink shut.
It breathes just a hint of oil... It might drip once in awhile.
Exekiel69
Aug 4, 2008 11:43 PM
displacedtexan
17
Dec 7, 2006 09:13 PM
Badd Dogg Guy19
17
May 27, 2005 12:43 PM
suzukiZrider
Jan 13, 2005 08:20 PM
Commatoze
0
Oct 15, 2003 12:33 PM
