Cranks waaay longer when restarting hot - why?
Old Sep 19, 2007 | 12:04 PM
CORed's Avatar
Unhappy Cranks waaay longer when restarting hot - why?
See my sig for what I am referring to.
Recently when towing moderately for a couple hours, about 5000 lbs at highway speeds in 80+ degree weather, I stop the truck after normal EGT cooldown.
About 10-15 minutes later when I go to restart it, it just cranks. I stop for a couple seconds and try again and it cranks and almost starts... then I stop for another couple seconds and try again... it normally starts then and runs fine. I can recreate this again an hour or two later the next place I stop.
When cold, it cranks over and starts right up normally.
Any ideas?
- My fuel pressure is a constant 15-16, but I have heard my return banjo bolt on the VP44 could be bad - no details on how this would cause hard start tho
- I have not checked codes but will report if I find any
Truck has only 71,000 miles.
Old Sep 19, 2007 | 12:11 PM
drafalske's Avatar
Please post your findings after checking the codes, could be lots of things wrong there.
Old Sep 19, 2007 | 03:48 PM
lotero's Avatar
i have been fighting this exact same thing for a while now and believe me i have tried just about everything, here is a good link to the hot start reflash that is supposed to help...
https://www.dieseltruckresource.com/...+start+reflash
Old Sep 19, 2007 | 04:22 PM
CORed's Avatar
lotero,
Thanks for the information... I followed it and it definitely applies to my truck as it was built in 2/00 and my Engine # falls between the range they give in the TSB.
Have you not tried this TSB yourself?
I think I will have to give the dealer a call next week after I get back to town and try to get this done. That should be a pleasant experience!??!! HA!
Old Sep 19, 2007 | 04:58 PM
lotero's Avatar
yea mine does too, and no i havent tried it will soon though, good luck with your dealer, i have "a friend in the business"
Old Sep 19, 2007 | 06:10 PM
Olratlr's Avatar
Hope you are not showing that dreadful po216 code.
Old Sep 19, 2007 | 08:48 PM
Gabe32's Avatar
it sounds to me like a vp44 going. I had that problem on mine when I had the 24 valve in it, and changed the vp out and it was gone
Old Sep 20, 2007 | 09:31 AM
CORed's Avatar
Well, the truck has been stopped and started several times since these symptoms occurred 4 days ago, but there are no codes... just "P done". I am leaving on a trip this weekend again for 1300 miles round trip. Maybe it these starting issues will occur then and I'll stop to check codes.
Old Sep 20, 2007 | 11:13 AM
Gabe32's Avatar
my pump never left a single code. It just kept getting worse and then I started getting the dead pedal. I replaced it before it left me stranded.
Old Sep 20, 2007 | 12:03 PM
CORed's Avatar
good (or bad) to know. Thanks Gabe. Crap... oh well, with 6 years and 71,000 miles currently, you'd think I'd still be under warranty from what I read in other threads regarding the 8-yr 136,000 mile warranty on the engine.
BTW, how long (miles) did it take after you first noticed this issue to finally get bad enough that you replaced the VP?
joeinblueout4u
16
Feb 16, 2013 04:46 PM
stange
Jun 22, 2010 11:08 AM
onemoretruck
13
May 4, 2010 09:13 PM
slubik
Feb 4, 2010 05:28 PM
screaminbanana
Aug 25, 2005 09:30 AM
