View Poll Results: what mileage did it occure
0-50,000 miles
7.69%
50,001-100,000 miles
30.77%
100,001-150,000 miles
53.85%
150,001 or more miles
7.69%
Voters: 13. You may not vote on this poll
cracked #53 blocks
Old Feb 10, 2005 | 12:32 PM
bluebull's Avatar
cracked #53 blocks
Only want to here from people who have seen the cracked block with there own eyes, not hear say or a friend of a friend told me type stuff.
Old Feb 11, 2005 | 07:24 AM
bluebull's Avatar
TTT,
64 views and no response. That could be good.
Old Feb 11, 2005 | 07:32 AM
mishkaya's Avatar
I don't think the problem is really as common as one might think. At any rate, I came across this thread over on the other site that might interest you:
http://www.turbodieselregister.com/f...=cracked+block
Of course I don't even have a #53 block, so it's pretty much all academic to me.
Mishkaya
Old Feb 11, 2005 | 10:42 AM
CORed's Avatar
bluebull, you should add a category for those with 53 blocks and over 100,000 miles that have NOT cracked yet. You could add more categories breaking down the mileage more, but that would give you the other side of the coin, at least for DTR members.
Where at in ND?
I'm originally from Bismarck.
Steve
Old Feb 11, 2005 | 12:29 PM
bluebull's Avatar
Thanks for the link, at least I can rest a little better now.
Old Feb 11, 2005 | 02:12 PM
dansdodgediesel's Avatar
I'd like to know what the chance of this happing is. I have alot of money into it, to get it the way I like it. I don't want to sell it but if the chances are good that it's going to brack, It's going down the road.
Old Feb 27, 2005 | 10:44 PM
MFEUSAF's Avatar
i have a 53 and it cracked and i have done almost everything to it even to the extent of pulling the eng and welding it and it still cracked. i think im goina just have to bite the bullet and buy a new block :-(
Old Feb 28, 2005 | 09:16 AM
blh1960's Avatar
My 53 has been repaired with Locknstitch. Holding so far! I will keep you guys informed of the situation.
Brian
Missouri
Old Feb 28, 2005 | 11:56 AM
chuck3's Avatar
If mine ever cracks, I will try the devcon. We use it at work to repair huge pump impellers (30000 gpm) that are damaged and worn. We have pulled the pumps back out after 4 to 5 years and the devcon is still holding, and the metal around it was worn.
I really think it would hold if the metal was prepared right.
Old Feb 28, 2005 | 12:42 PM
01redram's Avatar
well this is good news us 53 block owners.but not good enough for me.im still gonna trade mine in before the warranty expires
Old Mar 7, 2005 | 01:21 PM
Marine's Avatar
Veteran: Marine Corp
How about a column for those under 5000 that cracked?
Old Mar 7, 2005 | 07:19 PM
Diesel-Dan's Avatar
Uh......*BIG gasp of air!!!*..does running the truck with a hole in the rad (for a year!), and only running watter in the dead of winter and then the truck brakes something in the driveline and parking it outside of the shop on the coldest night of the year with the bolck heater pluged in for 3 days, but doesnt do anyting because the water level was too low and cracked the block from the tranny to the oil filter head, cracking the oil filter head spraying oil under the hood and interanly causing water to leak into the crank case as fast as you can pour it in, count.................getting fuzzy.......*THUMP* AND no....this wasnt my truck! haha.....
Old Mar 7, 2005 | 10:42 PM
Haulin_in_Dixie's Avatar
But I needed to vote twice... The original cracked at 60,000 and the one I was duped into buying cracked at 6000. You said only if you have actually seen one. I have "seen" a half dozen. You could not give me one unless I needed the rest of the parts.
roadhermit58
Dec 21, 2007 09:10 PM
janb
Jan 11, 2007 05:57 PM
Katmandu
Jan 16, 2006 08:30 AM
