cracked blocks
Old Dec 21, 2007 | 07:58 PM
roadhermit58's Avatar
cracked blocks
I have a '98 24 valve, in a 3500 drw. what blocks crack, where do they crack, can crack be seen easily? Thanks
Old Dec 21, 2007 | 09:10 PM
ironbutt's Avatar
The "53" block is the block that is prone to cracking. If you look below the injection pump near the oil pan you will see a prominantly displayed 53 cast in the block. If it's not there, you are lucky . The cracks lead to leaking of coolant thru the block to the outside (mostly). Welcome to the forum
janb
Jan 11, 2007 05:57 PM
Katmandu
Jan 16, 2006 08:30 AM
bluebull
Mar 7, 2005 10:42 PM
