Codes 1475 and 0602
Old Feb 10, 2007 | 03:10 PM
Gene007's Avatar
Codes 1475 and 0602
Fellow truckers, I have a couple of codes: 1475 which I do not know what it is and 0602 (P0602 Control Module Programming Error/NotProgrammed - What is this telling me?)
Regards,
Gene007
Old Feb 10, 2007 | 04:25 PM
Big Smoky's Avatar
P01475 Aux 5 Volt Supply Voltage High Sensor supply voltage for ECM sensors is too high. I'm not real sure what 602 is telling you. Maybe it has something to do with the Smarty? Did you maybe unplug it too soon during programing?
Old Feb 10, 2007 | 04:26 PM
graphitecumnz's Avatar
Regards,
Gene007
P0602 is from the Smarty...
Old Feb 10, 2007 | 04:32 PM
Gene007's Avatar
Thanks for the responses, P01475 Aux 5 Volt Supply Voltage High Sensor supply voltage for ECM sensors is too high. Has anyone had to adjust this supply?
Regards,
Gene007
Old Feb 10, 2007 | 05:13 PM
Tate's Avatar
Did you use the key-on-off method of getting the codes? Smarty tells you what they are in plain english. It also tells you that the 602 is normal with non-stock softwares.
Old Feb 10, 2007 | 05:26 PM
bent valves's Avatar
According to my Cummins manual a sensor may cause that code, P1475. All sensors are powered by the same +5VDC source and the same return (ground) from the ECM. It is not adjustable. The recommendation is to start unplugging the MAP, oil pressure sender, engine position sensor, and coolant level sensor, one at a time. When the fault goes inactive, investigate that particular circuit or sensor for a problem. With the fault indicating a voltage too high there may be a wire harness problem with the +5VDC source connecting to +12.
Old Feb 10, 2007 | 05:32 PM
crobtex's Avatar
I got the 602 with the Smarty and EZ. I disconnected the EZ, reprogrammed the Smarty back to stock and then to 7. All is well.
Old Feb 11, 2007 | 07:07 AM
Gene007's Avatar
Thanks to all. Bent valves, I'll try the elimination method.
Regards,
Gene007
LongBlackRam
Jan 8, 2009 07:58 PM
jcg
Dec 3, 2008 02:48 PM
Kenbob
Feb 7, 2006 01:33 PM
Lrdchaos
Sep 14, 2005 07:01 AM
Meatball
May 23, 2005 06:37 PM
