code 1475 :merged threads
Old Sep 12, 2005 | 09:59 PM
Lrdchaos's Avatar
what is code 1475 was installing a edge comp untapped and forgot to ground it, now I have this code?
Old Sep 12, 2005 | 10:05 PM
phox_mulder's Avatar
P1475 Aux. 5 Volt Output Too High
A couple(or more) starts after grounding it will probably make the code go away.
phox
Old Sep 12, 2005 | 10:52 PM
Lrdchaos's Avatar
where can I get a scan tool to erase the other codes?
Old Sep 12, 2005 | 11:01 PM
smokindog's Avatar
Question
What other codes do you have?
Old Sep 12, 2005 | 11:03 PM
Lrdchaos's Avatar
1963 or 1693 the companion code and the 0238 over boost code....Also my check engine light is staying on will that eventually go off?
Old Sep 13, 2005 | 06:54 AM
Lrdchaos's Avatar
Check engine light stuck on
I went to install my edge comp untapped and forgot to ground it, when I started it it threw a 1475 and a 0238 code. Now my check engine light wont go away. I left the batteries unplugged all night with the key on trying to drain the memory. Is it normal for the light to stay on, with the codes set?
Old Sep 13, 2005 | 07:04 AM
Shovelhead's Avatar
Administrator / Scooter Bum
It should turn itself off after a few restarts.
However the code will still be stored.
Your local auto parts chain might be able to clear the memory for you.
Old Sep 13, 2005 | 12:04 PM
CTD NUT's Avatar
phox
Phox, where is your source for codes? The source I use for DTC's said the 1475 DTC was some obscure BMW DTC!?!? Just curious.....don't imagine that I will bother with that source again!
Old Sep 13, 2005 | 06:14 PM
First I check here:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Then if that one doesn't have it, or I need a second opinion, I check here:
http://www.troublecodes.net/chrysler/96-01.shtml
Then if I'm still confused, I check here:
http://www.troublecodes.net/chrysler/99-01trk.shtml
Usually I believe the code is correct if 2 or more of the above agree on the definition.
There's still the odd one that neither of the three list, then I just do a google search on the code untill I find 2 or more pages that agree.
phox
Old Sep 14, 2005 | 07:01 AM
CTD NUT's Avatar
Hmm....thanks for the links.....much better than what I was using prior to this!
Gene007
Feb 11, 2007 07:07 AM
SSweeney
17
Jul 8, 2006 12:30 AM
Begle1
Mar 23, 2006 04:41 PM
pakman
Jan 17, 2006 10:16 AM
Meatball
May 23, 2005 06:37 PM
