Code P1693
Old Jun 18, 2009 | 08:48 PM
madmax44's Avatar
Code P1693
The truck is running great. As I was letting the turbo cool, I noticed the tach slightly varying between 850-900 RPM's. I shut her down and pulled code P1693, it was too late to hit AutoZone I'll go in the mourning. I bought the truck about 2 weeks ago and the IP is brand spanking new and the LP was moved to the tank, so I guess both were just replaced hopefully by Dodge! Should I lose sleep tonight worrying about this new IP going bad? The truck is bone stock With 106k miles.
Old Jun 19, 2009 | 05:34 AM
Mattg4x4's Avatar
I belive it is a companion code cheak codes and post back
Old Jun 19, 2009 | 07:36 AM
madmax44's Avatar
Had the codes pulled 2 came up twice
P0234- Engine overboost condition, turbo boost limit exceeded
P0236- Turbo boost sensor A circuit (MAP) sensor voltage too high for too long
Anyone have any ideas on the fix for this? Thanks
Old Jun 19, 2009 | 11:31 AM
Midnite's Avatar
Bad MAP sensor maybe?
Old Jun 19, 2009 | 11:43 AM
madmax44's Avatar
I will clean both sensors this weekend and see if that clears the codes. If not Dodge wants $290 for new Map and new harness!!! Cummins $84 for Map! Cummins dealer said in all his years he never had to order one.
DuaneWKKC
Jul 26, 2006 12:25 PM
Jonm_82_01td
May 17, 2005 11:24 AM
engcogod
Jan 11, 2005 09:48 PM
salty mule
Mar 17, 2004 05:59 PM
dansdodgediesel
Jan 2, 2004 04:30 PM
