Code 1690 def.
Old Aug 5, 2009 | 10:24 PM
ops_8_8's Avatar
Code 1690 def.
Looking for a definition for code 1690...
Ran a scan tool on my rig today, but no definition cam up with the code.
Old Aug 5, 2009 | 10:34 PM
ops_8_8's Avatar
Found this on Edge website
P1690 CKP Sens Does Not Agree with ECM CKP Sens
Anybody seen this one yet?
Old Aug 5, 2009 | 11:59 PM
KennyG's Avatar
Post
Code P1690 - Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor.
Brief Description: Problem in fuel sync signal. Possible injection pump timing problem. Low power, engine derated, or engine stops.
It could be that you have a bad Crankshaft Position Sensor or "CKP". The ECM interprets the sensor input to determine the crankshaft position, The ECM then uses this position , along with other inputs, to determine injector firing sequence and fuel timing. Hope this helps!!
Old Aug 6, 2009 | 01:26 AM
ops_8_8's Avatar
Very helpful... Thanks a lot!
DeweyND
Jan 9, 2009 08:28 PM
skidooer76
Oct 16, 2007 10:16 AM
demsmiths
Mar 30, 2005 03:35 AM
Ohio Joe
Nov 24, 2004 03:09 PM
