Code 1690 def.
Looking for a definition for code 1690...
Ran a scan tool on my rig today, but no definition cam up with the code. |
Found this on Edge website
P1690 CKP Sens Does Not Agree with ECM CKP Sens Anybody seen this one yet? |
Code P1690 - Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor.
Brief Description: Problem in fuel sync signal. Possible injection pump timing problem. Low power, engine derated, or engine stops. It could be that you have a bad Crankshaft Position Sensor or "CKP". The ECM interprets the sensor input to determine the crankshaft position, The ECM then uses this position , along with other inputs, to determine injector firing sequence and fuel timing. Hope this helps!! :) |
Very helpful... Thanks a lot!
