clutch question
Old Nov 20, 2005 | 10:53 AM
horton's Avatar
clutch question
what is the maximum horsepower/torque rating for a stock clutch on 2001 H.O.
Old Nov 20, 2005 | 11:32 PM
rebal's Avatar
it depends on how you drive and the condition of the clutch. i just changed my HOs with the few mods it has because it started to slip.90 k on the clutch.. others are running a lot more power and theres is holding
Old Nov 21, 2005 | 07:24 AM
horton's Avatar
thanks for your help the only reason i am asking is because i would like put a 50-70hp chip in my truck and wanted to know if i would need to upgrade my clutch to hold the extra hp & torque
Old Nov 21, 2005 | 07:29 AM
blackdiesel's Avatar
Registered
my stocker went out in my 02 HO at 110 thousand miles. i reckon it would have went alot farther but i installed a comp and 130 horse injectors. as far as i can remember, it held the 130 hp inj as long as you didnt get on it hard in the high gears.
Old Nov 21, 2005 | 07:35 AM
horton's Avatar
my 2001 has about 124k on it i dont know if the clutch has been replaced on it because i bought the truck used and it had about 96k at the time
Old Nov 21, 2005 | 09:19 AM
Bart Timothy's Avatar
Truck was brand new and only had 4000 miles on it, when mine started slipping. At around 340 -350 hp. Wasn't much in the way of after market clutches for the ETH/DEE in those days. What was avialable, was very expensive.
It's torque which makes them slip and driving habits can determine how long the clutch lasts. Keeping the engine out of the maximum torque band, above 2200 rpm, helps.
Old Nov 21, 2005 | 11:44 AM
dodgediesel4x4's Avatar
My old stocker would slip w/ the comp on higher settings. Once I tossed in some mach 1.5's, it was impossible to keep it from slipping, so I had to un-tap the wire. I figured I was around 325-ish hp when I could slip it very easily at higher rpm's.
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
