Check Gauges Light
Old Feb 20, 2007 | 01:43 PM
kb7kuh's Avatar
Check Gauges Light
I have a 2004 Ram HD CTD. I noticed that when it rains the Check Gauges light comes on and the Amp gauge drops all the way down to the lowest number. It is only the amp gauge, and when I ask the dealer, they say " I don't know what could cause that"
Has anybody out there run across this?
Thanks,
Don
Old Feb 20, 2007 | 01:51 PM
jiMMyCTD's Avatar
when i start mine (99) when its cold and the grids stay on or cycle not allowing the charging system to be at normal levals the light is on. but goes away once everything is up to spec...
Old Feb 20, 2007 | 02:32 PM
kb7kuh's Avatar
This happens when the truck is warmed up and on the road. I drive around 3 or 4 miles to work and it happened 3 times on the way home.
Old Feb 20, 2007 | 02:38 PM
jiMMyCTD's Avatar
well the obvious is that something is getting wet and causing a draw on the system which then triggers the check gauge light to come on.. is there a battery terminal archin off rain gutter along the hood or something else that could be getting wet and arching somewhere else???
Old Feb 21, 2007 | 09:43 AM
kb7kuh's Avatar
I will look at that. I called the dealer again yesterday and they are looking into it further. I will also look at the connections on the alt.
madhat
68
Oct 25, 2015 08:25 AM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
quantrill88
Dec 14, 2003 06:41 PM
