Bunch O' Codes
Old Aug 10, 2006 | 03:39 AM
lovinCTD59's Avatar
Bunch O' Codes
After trying to install my edge comp. It threw the check engine light.. I removed the comp and cleared the light it stayed off but i was bored and ran the test for codes and it gave me
1687
0237
0238
1474
0341- Going to install the new crank sensor soon....
Like I said The truck rungs great and the check engine light hasnt come on since i removed the edge.....
Any help would be great!!
Old Aug 10, 2006 | 06:46 AM
jrs_dodge_diesel's Avatar
1687 - No Cluster Bus Message
0237 - Turbocharger Boost Pressure Sensor Low
0238 - Turbocharger Boost Pressure Sensor High
1474 - Low Fan Control Primary Circuit Malfunction
They 1474 is really throwing me off as there is no fan for the ECM to control.
Are you running a boost fooler with the Edge?
Old Aug 10, 2006 | 06:50 AM
DieselDaze's Avatar
How can both occur?
Rich
Old Aug 10, 2006 | 08:22 AM
Originally Posted by DieselDaze
How can both occur?
Rich
Theory:
High boost code from Edge chip
Low boost code from leaving the MAP unplugged and running the engine (ive done that myself )
Old Aug 10, 2006 | 08:46 AM
CTD NUT's Avatar
According to my source, there is no 1474 DTC for Dodge in 2001....
As near as I can tell, 1474 is an OBD II DTC for Ford.....
1474 is stated as : P1474 HCF Primary Circuit Failure (Ford)
OR
P1474 LFC Primary Circuit Failure (Ford)
I'm not saying I'm 100% correct but this is what I come up with......To my knowledge, there is no PCM control of a fan circuit that would allow a DTC to occur if there was some type of fan circuit malfunction......somebody please correct me if I'm wrong.
Old Aug 10, 2006 | 08:52 AM
CTD NUT's Avatar
1687 is another goofy one too......JBODY are you out there?
Could this have something to do with the CANBUS connector that the Comp plugs into?
I think he could shed some light on these uusual DTC's.
Old Aug 10, 2006 | 05:40 PM
lovinCTD59's Avatar
Sorry...
Sorry for throwing you guys off but the code is actually 1475 not 1474... Like I said this all started after installing the edge comp
Old Aug 11, 2006 | 03:48 AM
1475 don't make much sense (to me) either. 1475 = Aux. 5 Volt Output Too High
johnny1509
Feb 10, 2011 09:19 PM
2 busy
Dec 4, 2010 10:29 PM
qzilla
Apr 9, 2010 07:55 PM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
