Bunch O' Codes
After trying to install my edge comp. It threw the check engine light.. I removed the comp and cleared the light it stayed off but i was bored and ran the test for codes and it gave me
1687 0237 0238 1474 0341- Going to install the new crank sensor soon.... Like I said The truck rungs great and the check engine light hasnt come on since i removed the edge..... Any help would be great!! |
1687 - No Cluster Bus Message :confused:
0237 - Turbocharger Boost Pressure Sensor Low 0238 - Turbocharger Boost Pressure Sensor High 1474 - Low Fan Control Primary Circuit Malfunction :confused: They 1474 is really throwing me off as there is no fan for the ECM to control. Are you running a boost fooler with the Edge? |
0238 - Turbocharger Boost Pressure Sensor High How can both occur? Rich |
Originally Posted by DieselDaze
[eyecrazy]
How can both occur? Rich High boost code from Edge chip Low boost code from leaving the MAP unplugged and running the engine (ive done that myself [duhhh] ) |
According to my source, there is no 1474 DTC for Dodge in 2001....
As near as I can tell, 1474 is an OBD II DTC for Ford..... 1474 is stated as : P1474 HCF Primary Circuit Failure (Ford) OR P1474 LFC Primary Circuit Failure (Ford) I'm not saying I'm 100% correct but this is what I come up with......To my knowledge, there is no PCM control of a fan circuit that would allow a DTC to occur if there was some type of fan circuit malfunction......somebody please correct me if I'm wrong. |
1687 is another goofy one too......JBODY are you out there?
Could this have something to do with the CANBUS connector that the Comp plugs into? I think he could shed some light on these uusual DTC's. |
Sorry...
Sorry for throwing you guys off but the code is actually 1475 not 1474... Like I said this all started after installing the edge comp
