Brake M/C replacement
Old Aug 17, 2009 | 04:39 PM
Bodean's Avatar
Anything (tricks) I need to know on a 99 2wd or is it just like any other M/C.
Any help would be great. Mines leaking!
Old Aug 17, 2009 | 05:21 PM
dozer12216's Avatar
Don't bolt on upside down.
Old Aug 17, 2009 | 09:13 PM
BigIron70's Avatar
Cummins Guru
Bench bleed first and I recomend using safety glasses while doing it. I had gotten brake fluid in my eye once, the hose blew off master cylinder. I swore I would never bleed a brake system again without eye protection on. The most painful thing you could imagine. Play it safe... put on eye protection. Wash off any brake fluid with water since it will take your paint off very fast if you don't.
Old Aug 17, 2009 | 09:21 PM
BigIron70's Avatar
Cummins Guru
Safe way to bleed master cylinder less chance of getting brake fluid in face.
MASTER CYLINDER BLEEDING
A new master cylinder should be bled before installation on the vehicle. Required bleeding tools include bleed tubes and a wood dowel to stroke the pistons. Bleed tubes can be fabricated from brake line.
BLEEDING PROCEDURE
1.Mount master cylinder in vise.
2.Attach bleed tubes to cylinder outlet ports. Then position each tube end into reservoir Master Cylinder Bleeding - Typical
3.Fill reservoir with fresh brake fluid.
4.Press cylinder pistons inward with wood dowel. Then release pistons and allow them to return under spring pressure. Continue bleeding operations until air bubbles are no longer visible in fluid
Old Aug 17, 2009 | 09:24 PM
BigIron70's Avatar
Cummins Guru
To complete replacement you will need to bleed base brake to remove any air in brake system.
NOTE: If master cylinder is replaced, bleed cylinder before installation.
1.Install master cylinder on the booster mounting studs.
2.Install mounting nuts and tighten to 28 N·m (21 ft. lbs.)
3.Install brake lines and tighten to 19-23 N·m (170-200 in. lbs.)
4.Bleed base brake system.
Old Aug 17, 2009 | 11:34 PM
Bodean's Avatar
Wow, thanks for the info.
Later,
Tiny
Sep 20, 2005 07:40 PM
NHDiesel
May 20, 2005 04:52 PM
sgT
Nov 30, 2004 01:54 PM
Luckycharm1
Oct 17, 2003 03:05 PM
Garz
May 13, 2003 12:01 AM
