Boost check question
Old Sep 9, 2005 | 06:58 PM
greenworks's Avatar
Should a person have air passing exhaust valves when 20 psi is on the engine checking the boost with an air compressor, is their a spot in the firing cycle that all valves would be closed? I remember once talking to a guy at a diesel shop that told me I should have no air movment past the valves but to me that was a near impossible statment unless I am not thinking clear. Chaasing some possible bosst leaks....... again
J
Old Sep 9, 2005 | 08:46 PM
Huff nPuff's Avatar
Th answer is no.Only one cylinder at a time will have the valves closed on the compression and power stroke.
Old Sep 10, 2005 | 07:33 AM
Mopar1973man's Avatar
At no point should there be both intake and exhaust open...
(I pretty sure about that...)
If you want to test the therory... Roll the crank to a new position and re-test.
madhat
68
Oct 25, 2015 08:25 AM
Adam3291
May 2, 2008 10:08 PM
GTSDave
Jul 8, 2005 09:06 AM
Gary C
Mar 15, 2004 02:53 PM
