blown head gasket or water pump failed?
Old Jun 18, 2009 | 09:06 AM
powermad's Avatar
so ive been smelling coolent in my cab when the motor is warm and the air or defrosters are on. and now im noticing that there is steam coming out of my vents? if it was a head gasket i would loose boost and see coolent, and if it was my water pump i would notice it from the heater vents... correct?
Old Jun 18, 2009 | 01:28 PM
Copenhagenjunkie's Avatar
that would be the heater core leaking.
Old Jun 18, 2009 | 04:03 PM
powermad's Avatar
ahhh!!! blankin son of a blank!!! one thing after another. so next step can anyone tell me the easiest way to deal with this fix
Old Jun 18, 2009 | 04:26 PM
scottsjeeprolet's Avatar
There is no easy fix. And while your under there change the AC evaporator core too.
Here's some helpful links.
https://www.dieseltruckresource.com/...e-t165900.html
https://www.dieseltruckresource.com/...l-t183867.html
Old Jun 18, 2009 | 04:41 PM
powermad's Avatar
is this something that will get worse and hurt my truck or can i hold off until i have the time and money?
Old Jun 18, 2009 | 06:22 PM
patdaly's Avatar
Just loop the hoses ( take them off inside the engine compartment and hook them together ) and you can run until you need the heater again......
Old Jun 18, 2009 | 06:30 PM
johnh's Avatar
that would also be a good way to confirm the problem
Old Jun 18, 2009 | 06:58 PM
powermad's Avatar
any link to which lines they are? i know nothing about heater cores. oh and thanks for the help guys!
Old Jun 18, 2009 | 11:26 PM
johnh's Avatar
on the passenger side by the valve cover to the rear of the engine are the heater hoses
storx
Aug 15, 2005 07:04 PM
Wolff
Apr 2, 2005 10:54 PM
Old Coot
Jul 28, 2004 07:48 PM
mike herron
Feb 1, 2004 11:19 AM
soopertrooperII
Jan 12, 2004 11:28 PM
