bleeding injectors
Old Nov 25, 2005 | 07:32 PM
trex's Avatar
bleeding injectors
when you bleed the air out of the inection lines how much pressure should come out? I bleed mine and only a small squirt with not much assumed pressure behind it came out. will the lift pump push through the injection pump if the truck doesnt start?
Old Nov 25, 2005 | 08:01 PM
MnTom's Avatar
Once you get fuel out of the fuel lines at the injectors you are pretty much good to go. You should only need to bleed a couple of them too. It will run rough for a little, but once all the air is out it should be fine. Why are you bleeding the injector lines? Just change filters or something?
Tom
Old Nov 25, 2005 | 08:20 PM
trex's Avatar
im having problems getting the truck to run. i think that the inj. pump is bad so im trying to eliminate all the other possibilities first. i just thought that the lines going to the injectors would have more pressure then they did. it really didnt spray much fuel at all.
Old Nov 25, 2005 | 08:22 PM
phox_mulder's Avatar
Once the air is bled out, they should spray pretty good.
Injector pump puts out something like 10,000 psi? or some outrageous amount.
I know it's high enough to pierce your skin should you have a finger right there by it.
phox
Old Nov 25, 2005 | 08:36 PM
trex's Avatar
well with the injector fitting loose enough that i could turn it by hand it barely squirted out the lines. bad vp44??
Old Nov 25, 2005 | 08:42 PM
P.J's Avatar
P.J
phox
Think I read somewhere they push like 19,400 psi? Or was that 14,900?
Whatever, its up there.
Old Nov 25, 2005 | 08:43 PM
P.J's Avatar
P.J
Did you pull the codes (or any display on their own in the odometer window?)
Old Nov 25, 2005 | 08:52 PM
trex's Avatar
check engine light was on and the check gauges light came on but never checked the codes. can you use a sequence with the ignition to check codes on a 99?
Old Nov 25, 2005 | 08:56 PM
Nope, you need to get them scaned on a 99.
phox
Old Nov 25, 2005 | 09:08 PM
P.J's Avatar
P.J
Bet you come up with P0216.
(Not good)
Old Nov 26, 2005 | 12:24 AM
jrs_dodge_diesel's Avatar
You only need at least three cylinders firing to be able to start the engine. Crack lines 1, 3, and 5, or 2, 4, and 6. Wait till all three squirt and then tighten them up. It should start and run rough until the air is purged out of the remaining three.
BTW some 99 truck can do the code retrieval with the key. I believe its the models just before the 2000 model came out.
Old Nov 26, 2005 | 02:00 PM
Andy505's Avatar
I only bleed two injectors....#1 and #3 when I mess with the fuel system...its starts every time.
chevummins
Jan 4, 2013 02:17 PM
RedRewster
Aug 31, 2010 04:38 PM
MoparMarv
Jul 26, 2008 11:44 PM
Mo. Dirtracer
Oct 29, 2006 08:55 PM
BIGOKIE
Jul 21, 2004 05:53 PM
