oil pressure sensor
oil pressure sensor
has and anybody changed this pressures at idle are down 10 to 15 psi at idle but under load back to normal dealer wanted 210.00 for the part it's outragous something that small coast so much. it just started this yesterday and oil was changed 1500 miles ago any ideas
bad 1 ton
bad 1 ton
Usually the sensors just fail rather than go bad.
But I guess anything is possible.
Have you hooked up a manual gauge to see if your engine is really running that pressure?
If you buy from Cummins direct the sensor is around 80 bucks or so.
Really though, I wouldnt drive until you figure out exactly what is going on.
well been driving all day no strange noises temp normal pressures drop off at idle first time its happened with 111500 miles maybe shes finally broken in if not time for a rebuild.what can you do i'll change filter tomorrow see what happens
You can read your pressure manually at the filter housing.
Go to lowes or home depot, ace or the like and buy a 1/8" brass hose fitting.
Then attach hose to a manual guage that reads to about 150psi.
You can buy a cheap air gauge from napa or the like for about 5 bucks.
For about 20 bucks you might be able to save your self some money.
Chances are you only need a sender. Go to Cummins and you should be able to get on a lot cheaper. If it is similar to the 12v one, you need to use a real deep 1 1/16" SIX POINT socket. Do a search and you should even be able to find a part number.
Tom
Tom
Bobcat698
Mar 25, 2008 09:42 AM
GlennRMK
May 24, 2007 10:46 PM
tyssniffen
Feb 11, 2006 01:28 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
