Bleeding every morning
Old Oct 13, 2006 | 08:13 AM
PChouinard's Avatar
I just replaced my lift pump and fuel filter. All my fittings seem good and I have no fuel leaks. However, I have to bleed my fuel system at the injector pump banjo and then crack my #1 injector while cranking to get the ol girl to start. Once it starts in the morning, it runs and starts good the rest of the day. Can air get in statically without fuel coming out when pressurized? Is this the end of my injector pump? Is there any problems running low-sulfer in a 99?
Old Oct 14, 2006 | 08:54 AM
Mopar1973man's Avatar
Me personally I think there is a problem to using ULSD in a 99...
Check out this link...
http://www.frontiernet.net/~mopar197..._cycle_oil.htm
As for bleeding the system every morning is telling me you got a fuel line leak. It's sucking air back into the system and losing prime. Check all you fuel lines for leaks or wet spots...
You might try bumping the starter in the morning and seeing if that help starting the truck.
Do you have a fuel pressure gauge? I HIGHLY SUGGEST you get one...
Old Oct 14, 2006 | 09:20 AM
Marine's Avatar
Veteran: Marine Corp
I think you might have to tighten your FF canister lid more. Did you lube the o-ring with fuel?
Double check all your fittings again.
Old Oct 14, 2006 | 09:27 AM
PChouinard's Avatar
I think I need to investigate the canister also and I'm gonna replace all my banjo bolt washers. I've been problem free with old #2 and B100. I just started having problems with low sulfer diesel. Thanks for the replies and Semper Fi Marine... (Cpl from '91-'96)
Old Oct 14, 2006 | 09:31 AM
Marine's Avatar
Oorah!
Take a look at this.
Old Oct 14, 2006 | 04:33 PM
PChouinard's Avatar
I think I'm going back to veggie gas. **** on OPEC and Chevron....
Old Oct 14, 2006 | 05:08 PM
nitrousn's Avatar
I would follow both the supply and return lines closely. They are known for failure behind the tank along the frame rail. The clips that hold them to the rail are the common places the lines fail. If you see and signs of dampness you can bet its pulling air in. The return lines will fool a lot of people and they are known to cause the problems you have.
Old Oct 15, 2006 | 07:01 AM
fschiola's Avatar
Originally Posted by Marine
Oorah!
Oh, that's just peachy. Even additives won't help.
maddog1927
0
Jan 6, 2009 12:33 PM
gpshemi
Oct 3, 2007 09:14 AM
PChouinard
Oct 13, 2006 07:31 PM
yomitch
Feb 22, 2004 11:34 AM
Lary Ellis (Top)
Nov 14, 2002 12:46 PM
