Puke Bottle/Observation/Rant
Old Oct 10, 2006 | 04:40 PM
qwest's Avatar
Puke bottle removed, nice clean engine now. I noticed the bottle was about 1/6 full: OF CLEAN Oil, looked like oil right out of the container, after 5000 miles on the oil ( burned 1 qt ), I did slightly over fill , just a tad over full, Question Why only clean oil???? Rant: Do you ever think you would see a Jap Truck with a Puke bottle? What werethe engineers thinking... 40K truck , a cummins engine, and a cheap 2 ct little plastic bottle attached, Beam me up scotty...
Old Oct 10, 2006 | 09:58 PM
1-2-3's Avatar
Just a plain ole guy
No bottle here. Just a nub of a hose. And not a drop on the radiator. Just looked today make sure today. I did have some gunked up battery terminals. That's taken care of though.
Old Oct 11, 2006 | 09:10 AM
Mopar1973man's Avatar
I've got a solution to that problem... It will cost about $10 bucks to builds it though...
http://www.frontiernet.net/~mopar197...kcase_vent.htm
Check it out it does work good...
Old Oct 11, 2006 | 03:13 PM
qwest's Avatar
Did mine at No Cost, Left over metal vent tube with a
'U' shapped hose on bottom, found a flex rubber hose from
'? something' and routed through front cross member,
Will see where vapor goes,
Clean Oil in bottle is still a mystery, any guess's...
Old Oct 12, 2006 | 08:30 AM
Be careful about the routing you got...
1. Under heavy braking you can still spill oil out the breather.
2. Under extreme descents you can still spill oil out the breather.
That why I routed over the top of the engine. For both 1 & 2 it keeps the oil from running out the end of the tube under both conditions.
3. If the hose is too long you could freeze it shut. There is water vapor also that comes out of that tube...
Old Oct 15, 2006 | 07:18 AM
fschiola's Avatar
That bottle was there to eliminate the "environmental concerns" from a few drops of oil dripping on the ground and making spots on a nice clean driveway or garage floor. There are a lot of things, I'm sure, that were designed to eliminate "problems" that consumers didn't have to face before they owned a truck with a diesel engine like hard starting when cold, fuel gelling, etc.
paparcl
17
Sep 20, 2006 12:33 AM
J BODY
15
Sep 8, 2005 08:12 PM
TPilaske
Jan 10, 2003 09:07 AM
