BHAF
Old Nov 24, 2002 | 10:45 AM
Marine's Avatar
Veteran: Marine Corp
Re:BHAF
Pistolwhipt- I have the heatshield template if you want it. Just e-mail me at home.
Mike
I also have a 4-3 pvc reducer between my bhaf and hose. Looking for something different.
Old Nov 29, 2002 | 05:12 PM
muddymess's Avatar
Re:BHAF
someone asked for a pic of the hsing for my mhaf. made from allmnm pipe w/ hole cut for fender air. also hole cut in cowl area to utilize the cool clean air there. the allmnm absorbs too much heat so some other material be bettr. it will be replaced w/ a stainless version. im still wishin scott will manufacture a scotty II for a mhaf<br><br><br><br><br>this aint the purtiest but it is temporary till a stainless version is made
Old Nov 29, 2002 | 05:15 PM
muddymess's Avatar
Re:BHAF
and anothr<br><br>campershell weathr stripping tape is used to keep warm air from coming in leading end
Old Nov 29, 2002 | 05:16 PM
muddymess's Avatar
Re:BHAF
Old Nov 29, 2002 | 06:18 PM
Alan_Reagan's Avatar
Re:BHAF
[quote author=Gary - KJ6Q link=board=4;threadid=7210;start=15#71904 date=1038175381]<br>I'm currently running an informal &quot;test&quot; of a K&amp;N in my drilled airbox - carefully monitoring intake venturi of the turbo for signs of dirt buildup - after about 5000 miles or so on the stock filter, I carefully swabbed that intake with a clean tissue, which I then carefully saved in a sealed wrap, then installed the K&amp;N - in another few thousand miles, I'll do it again on a clean area of the same tissue, and compare - pic below of what a stock filter lets past...<br><br>If I'm not happy with what I see, I'll convert to the BHAF - sure would like one of the neat stainless steel mount/shield setups one fella was making and selling for a while...<br>[/quote]<br><br>Gary, I'll be interested to see your results. I did the same thing but in reverse but I didn't save the wipe. After 3K miles, I swabbed the inside of the intake at the turbo blades and the swab was black. It was oil and I immediately removed the K&amp;N and installed a BHAF. 30K miles later, still no dirt on the intake at the turbo.
Old Nov 29, 2002 | 06:41 PM
DPG's Avatar
DPG
Re:BHAF
Here's a pic of my BHAF, with the heat shield made from Marine's template. The filter is a NAPA #2790.<br><br>It seems to work great, you can hear the turbo spool up really well! The EGT's are lower than with the stock box, also.
Old Nov 29, 2002 | 07:36 PM
TX Ram's Avatar
Re:BHAF
Could someone please post the measurements for the heat shield? I got the file from Marine but have since moved back to school and the computer here won't open it for some reason. Thanks for any help!
Old Nov 29, 2002 | 07:51 PM
scottrod's Avatar
Re:BHAF
pm me your email addy and I'll send em to ya ;D
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
