Bad sound
Old Jan 31, 2007 | 02:10 PM
5150's Avatar
Angry Bad sound
I'm new but this is buging me i have a stock 2000 it has 120000 and just replaced the vp44 and lift pump now i'm hearing a sound sounds like a rod starting to knock its really quiet not sure if it is just normal diesel sounds
Does anyone know if i can check rod barings by pulling the oil pan down?
What about replaceing a rod baring can that be done?
Old Jan 31, 2007 | 02:27 PM
Ram1999's Avatar
Noises are hard to figure out online.
But, if it makes you feel better...mine has sounded that way since '99 and even worse since ULSD fuel. Some of us are adding 2 stroke oil to the fuel tank to help lube the pumps and quiet it down some.
Old Jan 31, 2007 | 02:59 PM
Mike D's Avatar
I suspect what you are hearing is normal. If you are unsure, maybe send in for an oil analysts would help.
Old Jan 31, 2007 | 03:50 PM
sacnvr2l8's Avatar
If these trucks don't knock rattle and shake somethings wrong
Old Jan 31, 2007 | 05:07 PM
5150's Avatar
How could i send in a oil analysts?
How much 2 stroke oil do you add?
Old Jan 31, 2007 | 06:24 PM
Tate's Avatar
I run a 100:1 fuel/oil. Check your exhaust manifold gaskets. Rumour has it that a leaky gasket can make it sound like the engine is coming apart.
Old Jan 31, 2007 | 07:17 PM
Ram1999's Avatar
Not sure how to figure 100:1...
I add 1 qt to a tank full.
Old Jan 31, 2007 | 09:06 PM
CTDYoungGun's Avatar
i'm with these guys...these inline motors rattle and roll quite a bit but that's how they operate...and if you're curious about the rod bearings and want to pull the oil pan then set aside a weekend and a place where you can swear profusely...lol...you have to jack the motor up to get enough clearance to drop the pan out of the way...and it's no fun at all...2cents...
Old Jan 31, 2007 | 10:06 PM
Tate's Avatar
My usual fill is 100 litres, I add 1 litre of oil. Basically, a litre a tank.
Old Feb 1, 2007 | 01:42 PM
ib516's Avatar
Not sure where you live, but in Canada or US, all you have to do is email Blackstone Labs (that is one company that does oil analysis, there are more) and request a kit. They send everything you need to get an sample analyzed to you for free. You take a sample of oil at the next oil change, then send it back to them with a credit card #. They will email and send a hard copy of the report back to you. Then you need to surf on over to the forums at bobistheoilguy.com, and do some reading to interpret the analysis. That will tell you if your Cummins is sick.
Oil analysis is about $20. Well worth it IMO.
samiam4
Dec 19, 2012 12:08 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
jlipskoc
Dec 4, 2005 02:35 PM
C Pierce
Mar 21, 2005 08:41 AM
