Autopsy results on lift pump
Old Oct 3, 2005 | 10:09 PM
phox_mulder's Avatar
Originally Posted by DPG
This new lift pump kit is for what year trucks?
Pretty sure it is for all 24 valve engines, 1998.5 to current,
that would include your 2003.
phox
Old Oct 4, 2005 | 11:10 AM
HOHN's Avatar
phox
Yes, and it's completely useless for a performance application. You'd be surprised how easily you can suck it to 0 psi when you uprate power. Worse than the original LP
Old Oct 4, 2005 | 12:06 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Not really on the topic of the thread....
But has anyone added a "regular" lift pump along with the new in-tank pump?
Old Oct 4, 2005 | 01:36 PM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Ed, along those same lines. If the in tank pump is supplying adequate flow at a lower pressure AND the OEM pump is supplying a lesser flow at a higher pressure, could there be problems? The OEM pump displaces MAYBE .15 cubic in per rev. Flow specs are ~45 oz in ~25 sec. Pump would have to turn ~1500 rpm just to keep up with the flow and not produce any pressure on its own. (add mind is wandering smilie).
Thanks Ed for throwing a whole lot of IF's into this equation. May have to have a cold one an hour before going home time.
Has anyone mounted an OEM pump at the tank? The OEM would work in the tank since the motor housing is full of fuel anyway. Mount the tank high along the firewall and eliminate the pump all together
Old Oct 4, 2005 | 03:28 PM
HOHN's Avatar
In series? In parallel?
In series, it defeats the purpose. Just like with twin turbo-- you'll never have more air than the "big" turbo gives.
Only with the in-tank fuel pump, it's like having twins where the "big" turbo is an HY35/9-- kinda limits flow.
In parallel, things get very complicated very quickly.
Old Oct 4, 2005 | 05:40 PM
shortround's Avatar
Thanks HOHN, that's what I was trying to say.
Old Oct 4, 2005 | 07:32 PM
Vulcan's Avatar
Shortround,
Thanks for the work you put into this!
Eric
Old Oct 4, 2005 | 08:14 PM
george7941's Avatar
Putting two pumps in series will help in certain situations. You could have more flow because restrictions further downstream of the pump might have restricted the flow too much with just one pump. A second pump in series will certainly increase the pressure considerably. Check out an old thread of mine titled 'fuel pressure arithmetics'. I tried two pumps in series and the pressure was so high (27psi) that I ran into hard starts.
Old Oct 4, 2005 | 09:30 PM
fschiola's Avatar
Sort of like the old Model A's ?
Old Oct 4, 2005 | 10:54 PM
Huff nPuff's Avatar
Some guys have already posted results.
HChojnacki posted on the TDR, He is running the new in tank pump with a stock auxillary pump and is getting 26to 29 psi of fuel pressure at idle.
Old Oct 4, 2005 | 11:31 PM
Huff nPuff's Avatar
Thats correct Hohn Its just like twins.
The twins are limited by the effective area of the intake.The old fuel module in the tank has an effective area of 5/16 of an inch intake.You can drasticlly improve the volume of the system by pushing the fuel thru that opening at 12psi.than trying to suck it thru the same opening.
Txwelder
Nov 26, 2025 01:53 AM
cquestad
22
Apr 25, 2008 02:24 PM
John Mule
Mar 11, 2007 07:18 AM
Kayakit
Dec 28, 2006 12:12 AM
Txwelder
May 19, 2005 06:10 PM
