Attention: Check your auto trans cooler lines!
Old Feb 17, 2010 | 03:22 PM
sheriffav8r's Avatar
After driving my new Goerend tranny around town for a couple of weeks I noticed ATF draining at an ever increasing rate from under my truck. 4 cans of brake cleaner later I found the leak. I put the truck in drive with the parking brake on and the transmission warmed up (the cooler starts flowing at around 110 degrees F) and saw it leaking from the front of the truck. The tranny cooler lines are silver colored aluminum 1/2" lines that run under the engine, over the engine brackets, and to the cooler. If you trace your lines from the water/tranny fluid heat exchanger (right side of engine that looks like a round manifold with those 1/2" lines going in and out) to the front they will pass over a brace about 8-10" behind the tranny cooler. These lines were rubbing on the metal brace and sprung a leak.
I did an easy repair with some fuel hose cut longways and placed over the tube and secured with a couple of hose clamps over the hole. A better fix is coming when I can devote the time, but this one seems to work for now....
The nice part is that the entire underside of my truck is now preserved in ATF, ready for a harsh winter here in southwest Florida, heh, heh....
Old Feb 17, 2010 | 07:13 PM
2500superram's Avatar
i find this truck has alot of thing's running over and rubbing on alot of thing's.
Old Feb 17, 2010 | 07:48 PM
305motorsgt's Avatar
Had the same thing happen to mine, the lines rubbed through where a bracket had rusted off. I had changed the oil and was checking for leaks when Niagra Falls happened.
Old Feb 18, 2010 | 06:38 PM
i had both the abs sensor wire's for the front wheel's wear from rubbing on the brake line's.dumb dodge engineer's
FRANKV569
Apr 21, 2014 08:35 AM
dynodave
Oct 2, 2013 09:50 PM
banks twinram
Sep 30, 2010 01:39 PM
EClancy
Jan 16, 2007 09:27 AM
robox
Nov 4, 2005 01:33 AM
