APPS Sensor location??
Old Mar 4, 2007 | 05:27 PM
raybob_99's Avatar
Friend said it was under black plastic cover but not sure what i am looking for. Can someone post a picture of this for me. Thanks
Old Mar 4, 2007 | 05:39 PM
Tate's Avatar
Front of the engine, on the driverside, just below and in front of the intake. Black cover has four phillips head screws. Under that is the APPS unit. You will also see just above the IP three 15mm head bolts. Those hold down the bracket the APPS bolts to.
Old Mar 4, 2007 | 05:42 PM
mikmaze's Avatar
depends on which year you have, and if you are lucky it can be in three locations on an 04.5, it could be located down by the go pedle, up in front of the air intake horn, or under the drivers side battery....... yup, those are the three possibilities on an 04.5.
Old Mar 4, 2007 | 07:20 PM
raybob_99's Avatar
APPS location
Ok will look again tomorrow, took off balck cover and didn't see anything. Mine is an 01 model. Does anyone have a picture?
Old Mar 4, 2007 | 08:12 PM
chadwick's Avatar
when you take that black cover off and you see where your throttle cable hooks up. The point where it hooks up is the apps. It is all one big assembly. The actual sensor part is behind all that, you cant see it without taking the apps unit off. There are 5 or 6 bolts holding it on. The throttle cable comes off easily with a flathead screwdriver to pop it off. The other two slide foward to get them off
Old Mar 5, 2007 | 12:00 AM
Tate's Avatar
I'll upload some pics of it.
Old Mar 5, 2007 | 02:12 AM
1-5-3-6-2-4's Avatar
Its the pear shaped black plastic cover just half under the intake elbow, front of the head.
Old Mar 6, 2007 | 09:00 AM
Kent Earnest's Avatar
raybob,
I haven't been a TDR member for a couple years but my photo galleries are still there. Here's a link to pictures I took when I replaced my APPS. Hope this helps.
http://www.turbodieselregister.com/u...&albumid=16378
supr
18
May 21, 2007 09:29 AM
JohnTcraigJr
Apr 29, 2007 01:17 PM
59FORD
Apr 7, 2006 12:28 AM
napa 600
Jan 20, 2006 02:57 PM
Hoss15
Jul 18, 2005 04:26 PM
