APPS/ECM/Fuel Pressure?
Old Aug 13, 2007 | 08:52 AM
Doug_TX's Avatar
Okay, I've thown a P0121 code (low APPS voltage). I cleaned out the connectors on the APPS, but haven't gotten to clear the code. But I'm wondering if I have other issues here. Let me explain.
First, ever since I've installed a FP gauge (Q'zilla Commander, and yes, I have the updated sensor) I've had erratic FP readings. Changed from the stock location LP to a Holley Blue pusher located just ahead of the tank. But still have the erratic FP readings (but with ~14 - 16 psi). I also have the dreaded P0216 code too. But when I turn the key to the ON position, I hear the LP bump, but it only runs for (at most) a second. Normally it's just a little 'burp'. So I'm wondering, could there be a problem with the ECM? Could it be sending an intermittent RUN command to the LP? Has anyone heard of this happening? Does anyone know of a source for the APPS? ECM?
Old Aug 13, 2007 | 09:15 AM
crobtex's Avatar
As you already know, the 0216 is not good and could possibly be causing some of the codes. I don't know that for sure, but it would make sense.
Have you done the APPS Reset and/or Calibration found in the Tech Facts? Either/or one of those might get rid of the P0121.
Don't know anything about the Commander, but sometime a small leak letting air into the line will cause erratic readings.
Old Aug 13, 2007 | 12:19 PM
Doug_TX's Avatar
Done the APPS reset, but haven't done the recalibration.
On the Autozone site I see a relay called:
Relay - Decelerate Fuel Cut-Off
Can't locate this on the diagram. But if there's a relay shutting off the fuel on decelerate, could a bad (or mis-calibrated) APPS be tellling the ECM that the vehicle is in 'decelerate' mode and cause a shutoff?
And yes, I know the P0216 isn't good. But I'm running good FP now so it might be an old code as I haven't had them cleared.
Old Aug 13, 2007 | 12:50 PM
blackdiesel's Avatar
Registered
My self and one other on here had the 121 and it took a new ECM to fix it. Im not saying that's your problem, but it was mine.
Old Aug 13, 2007 | 12:53 PM
Doug_TX's Avatar
Given that the APPS is about $475, I can only imagine how painfully expen$ive that was.
Old Aug 13, 2007 | 02:56 PM
crobtex's Avatar
It's been a few years, but I got my APPS from Cummins Southern Plains for about $336. I'm sure they've gone up, but try a Cummins dealer first.
Old Aug 13, 2007 | 03:06 PM
Registered
Got a used one for $200, and hohn got his under warrenty
Old Aug 13, 2007 | 05:25 PM
Doug_TX's Avatar
Where did you find a used ECM?
Old Aug 13, 2007 | 07:03 PM
Registered
A salvage yard we do alot of business with found it for me in SC. and had it shipped to me. There is also a guy on ebay that takes apart alot of these trucks called redline, here in AR. that sells them also. Bob wagner on here might have one too.
ratat98
Sep 18, 2016 07:34 PM
jrussell
17
Sep 17, 2007 06:38 PM
cuda72
May 28, 2007 10:43 PM
sluggo42
Nov 21, 2006 03:12 PM
Ohio Joe
Jul 12, 2004 12:13 PM
