Anybody have experince with the p0122 code?
Old Nov 25, 2005 | 05:36 PM
greenworks's Avatar
Question Anybody have experince with the p0122 code?
Pullled out the scanner today after a couple sesions of stumbling around 1200 rpm. p0122 is a low apps voltage so I checked the voltage and it is exactly what the tag says when I set it months ago? I also noticed after extended drives (1-2 hours) with criuse the truck will idle at 1200-1700 rpm until the truck is shut off then turned back on, anybody ran in to this??
I am obvouilsy targeting the apps but what can you do if the voltage is good at idle I may hook up a metrer tonight and move the pedal to try to find a weak or dead spot.
Jason
Old Nov 25, 2005 | 05:53 PM
piperca's Avatar
I have a new APPS being shipped as I type.
I had the code pop up when I was having tranny lockup problems. I reset the voltage and added a DTT filter and that seemed to fix it.
A few days ago, I threw the same code, but this time I am experiencing loss of power. I can accelerate to about 65 on the freeway, but if I try to accelerate, after cruising at that speed, the truck doesn't want to do anything. Around town, the truck seems to perform fine. I tried resetting the code, but it immediately comes back.
Funny thing is, it's throwing 3 codes and all 3 are the P0122 code.
Old Nov 25, 2005 | 06:28 PM
greenworks's Avatar
piper.. did you ever get a series of stumbles?
Old Nov 25, 2005 | 07:36 PM
piperca's Avatar
Yes, but only when accelerating from a stop. That's what normally lead to the code being thrown. The truck would just bog down, like it was starving for fuel. If you're going to swap out the sensor, check out Ebay. I got mine for $207.50, including shipping, and it's new.
sleepr tsi
Nov 11, 2008 04:47 PM
82NDSNPR
Jun 16, 2008 09:19 PM
mountainsledhea
Nov 2, 2006 06:22 PM
swapmeetlouie
Mar 2, 2006 08:54 PM
Puke
Dec 19, 2005 06:59 PM
