Error code P0122 TPS/pedal postion sensor
Old Mar 2, 2006 | 07:11 PM
swapmeetlouie's Avatar
Gentlemen, new to the forum and Dodge trucks for that matter. Just got a 99 2500 long bed QC 5spd. CEL on with code of P0122 Pedal position sensor/TPS. You guys have any suggestions for me? Ive cleared it a dozen times but it keeps coming back. Any help is appreciated.
Old Mar 2, 2006 | 07:15 PM
graphitecumnz's Avatar
are you having any other symptoms?? and have you tried the reset procedure(s)??
else it may be time to put on a new APPS.... p/n is 53031576.
Old Mar 2, 2006 | 08:19 PM
no other symtoms, I was just gonna run it till it takes a shat. I unhooked the batteries overnight and reset the CPU, is that reset procedure you are talking about? I am only getting about 12 mpg around town, is that normal? Also just pulled the codes again and got P0122 again but included P1690 Manufacturer Control Auxillary Inputs/Auxillary Outputs whatever the hell that is.
Old Mar 2, 2006 | 08:28 PM
It's odd that you have no other symptoms than the P0122 code.
P1690-CKP SENSOR DOES NOT AGREE WITH ECM CKP
SENSOR
perhaps your crankshaft position sensor is the real problem here...
here's one APPS reset procedure... there is another one but I don't have the link to it.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
and 12 mpg sounds low...
Old Mar 2, 2006 | 08:54 PM
thanks for helpin a newbie, I apprecieate it!
whosdunit
May 17, 2014 08:54 AM
doorguy
May 19, 2008 10:30 PM
bcool
Jul 14, 2007 11:32 AM
tcafan
Aug 22, 2006 06:45 PM
wildmann
Aug 14, 2005 07:15 PM
