Adding 2 stroke oil to Fuel
Old Feb 27, 2008 | 09:10 AM
  #106
offroad's Avatar
Is this good for a 94-97 P Pump truck?
Old Feb 27, 2008 | 09:55 PM
  #107
Dangerous Dave's Avatar
Got 35.030 gallons today and put it in on top of 30oz TCW3
Truck isn't silent, but there is a difference, and VIVA LA DIFFERENCE!!!
Old Feb 27, 2008 | 10:02 PM
  #108
wcbcruzer's Avatar
Yes, you can run it with no problem.
Old Mar 31, 2011 | 01:14 AM
  #109
mstep3's Avatar
Originally Posted by D.S.
Im curious what the injector pump noise sounds like. There is a slight ticking noise thats only really noticeable at certain rpms or when the engine is heavily loaded (like going up a hill w/ my 24ft stock trailer). THis noise seems to come from the left side of the engine (somewhere behind the steering wheel)--is the the IP? thanks,
Drew
i've had a similar ticking noise in my 02' that you are describing that is rpm related & have always wondered if it was the injection pump. tick sounds like it's almost coming from the dash behind the steering wheel. had the tick since about 20,000 miles on the truck & doesn't seem to matter if it's hot or cold....never been able to get rid of mine though even after adding 2-stroke oil. did you notice any less of the ticking noise after using 2-stroke oil?
Old Apr 6, 2011 | 06:17 PM
  #110
dcbaker's Avatar
I think I'll be trying 2 stroke oil in my tank. I have a few bottles of AMSOIL Fuel Additive left. What is the general consensus? Is the oil additive enough? Should I add it with the 2 stroke oil or half and half of each?
I would like to keep using the AMSOIL to keep injectors clean.
Old Apr 6, 2011 | 08:51 PM
  #111
wcbcruzer's Avatar
I stopped using it.. It'll ruin my new catalytic converter..
Old Apr 6, 2011 | 09:31 PM
  #112
dcbaker's Avatar
wbcruzer, the AMSOIL or 2-stroke oil?
2001 2500 SLT QC CTD, Auto, Stock
Old Apr 6, 2011 | 09:35 PM
  #113
wcbcruzer's Avatar
I mean the 2-stroke oil...
Old Apr 6, 2011 | 11:52 PM
  #114
mstep3's Avatar
2-stroke oil plugs up the catalytic converter?
Old Apr 16, 2011 | 02:05 PM
  #115
real426maxwedge's Avatar
I havent tried running the 2 cycle oil. I have always ran the marvel mystery oil. I have a 2003 and 2007 CTD.
Old Apr 16, 2011 | 10:02 PM
  #116
wcbcruzer's Avatar
Well it'll mess it up. Think I read it in the owner's manual somewhere.
Old Jun 9, 2011 | 06:05 PM
  #117
mattn124's Avatar
I was just wondering,, does it metter much what brand/type of 2-stroke oil to run?
I just now started researching this topic and I think I am going to give it a try! I was cleaning out the shed and garage last week and I have several small bottles of various 2-stroke mix (poulan, tech 2000, homelite, etc...) can I mix them together in my tank?
Is there something that will be on the label I should look for, a certainb type or rating from some governing body? Or can I just burn through them all.
I dont want to run them in my 2-stroke equipment because everything I have is a Stihl and I run their stuff for them
Old Jun 9, 2011 | 06:18 PM
  #118
dcbaker's Avatar
Just as long as it is ashless 2-stroke oil it should be fine.
Old Jun 16, 2011 | 09:44 PM
  #119
old 300's Avatar
Make sure its ashless, I use Wally's world TCW-3 outboard oil. Been using it for years.
Old Jun 22, 2011 | 12:48 AM
  #120
spruce's Avatar
for those concerned about 2 cycle plugging up the cat?...........how do you explain the use of a cat on many modern 2 cycle engines going back to the mid 1980's used first on Yamaha's RZ500
