5speed tranny problem!!!!
Old May 2, 2007 | 07:52 PM
solostyle1's Avatar
When i accelerated today in 5th gear something happened. It now makes a loud noise like the gears are seriously grinding. 1-4 gears work just fine. any suggestions?
Old May 2, 2007 | 08:30 PM
J Lent's Avatar
Search 5th gear nut....sounds like the culprit. What year truck?
Old May 3, 2007 | 02:56 PM
solostyle1's Avatar
98.5....i had the 5th gear nut problem on my old tranny and when it went out..it was out....there was nothing...it was like i was in nuetral and reving it up..now in the new tranny its actually grinding....maybe the nut didnt back completly off yet???
Old May 9, 2008 | 10:40 AM
wadecool's Avatar
If I were you, I'd get the rear tranny cover off asap & check it out.
Old May 9, 2008 | 03:55 PM
Grease Monkey's Avatar
You could of ripped the splines out of the 5th gear syncro hub. I fixed one that we thought was 5th gear nut issue, but was the hub instead.
Old May 11, 2008 | 09:25 AM
Ram1999's Avatar
I have had the same problem (I think) for a few weeks now, still haven't found the problem. It shifts fine, 5th gear still works, just makes noise in 5th when on the throttle. Let off and the noise goes away. I don't want to drop the tranny, but I might have no choice. Hoping to find the problem before I do that.
Old May 12, 2008 | 03:53 PM
wadecool's Avatar
You don't have to drop the hole tranny, just the rear cover.
Old May 12, 2008 | 06:36 PM
Ram1999's Avatar
Thankfully I haven't spent much time under my truck so I don't know exactly what you mean....but I am interested.
I know there are two plates with 6 bolts, one on each side of the tranny. Could you please explain further about how to do this?
Thanks.
Old May 14, 2008 | 05:20 AM
Ram1999's Avatar
Hoping for a little help before the weekend. Thanks
Old May 16, 2008 | 01:29 PM
wadecool's Avatar
Ram1999, you want to drain your tranny, drop the transfer case, and then remove the rear cover from the tranny. Then you can get to the 5th gear & see what's going on. Its not too hard. I think you may need to put a jack under the tranny while you do this. Be careful not to strip the bolts that hold the rear cover, its easy to do. If you want, send me a private message & I'll give you my info to talk you through it.
tonyengland
Nov 28, 2011 01:54 PM
CTD2001
15
Apr 4, 2006 11:41 AM
possum
May 27, 2005 08:08 AM
fitzydog
May 26, 2005 10:59 AM
DAMAN
Mar 2, 2003 05:53 PM
