47re trani fluid and filter change
Old Sep 27, 2006 | 09:15 PM
mattzram's Avatar
Expecting my filter and gaskets from geno's tomorrow(?). I haven't got a service manual yet, are there any tricks or advice for changing the filter, fluid and adding a drain plug? Is it as straight forward as dropping/draining pan and changing filter, it's a 2002 2500 4x4 with 30,000 miles. Thanks.
Old Sep 27, 2006 | 10:43 PM
GSP's Avatar
GSP
Did you get the hard nylon thick gasket. Its the cats meow. You can reuse it , and it doesnt leak, put it on dry no gasket sealer. They say you need longer pan bolts for the thick gasket so you hit all the threads in the aluminum case , if the bolts are to short you could strip the threads. My bolts were long.
Yep . its straight foward. Get a big wide bucket. 2 vb bolts hold the filter.
I mig welded a drain plug on my pan.
Old Sep 28, 2006 | 03:54 PM
RowJ's Avatar
Very straight forward... but plan ahead. Have something level that slides under pan, about 1" below it. May help catch the pan coming out. But is a big help holding the pan in place while getting the bolts started back in, especially if your working alone.
Getting pan, gasket and bolt holes lined up, and still having a free hand to insert first two bolts can be tricky. Extra pair of hands is great.... if not, I use a block of wood, than shim the pan & gasket up into place.
Expect a big mess, till you get a drain plug installed
RJ
Old Sep 28, 2006 | 04:40 PM
ib516's Avatar
Make sure you refill with ATF+4 only. Anything else can cause shudder, and ATF+4 is good stuff (synthetic so I hear).
Old Sep 29, 2006 | 01:08 AM
J BODY's Avatar
.....so many uses, and makes trans service work a breeze.
Old Sep 29, 2006 | 04:07 PM
Snapper's Avatar
I second the above
Old Sep 29, 2006 | 08:05 PM
dieselfan's Avatar
what is it?
thanks dieselfan
Old Sep 29, 2006 | 09:13 PM
GSP's Avatar
GSP
Its a Humming bird feeder.
Old Sep 29, 2006 | 09:37 PM
dieselfan's Avatar
sorry but im lost, how do you use it ?
thanks dieselfan
Old Sep 30, 2006 | 01:03 AM
J BODY's Avatar
It's a fluid evacuator. It comes with sections of line and you pump the top handle to create a vacuum. I bought a piece long enough to get six quarts out of a Dodge truck trans. The one shown above can be found for around 60-80 bucks. There are also ones that you flip a switch and allows you to pump from the container and also ones that utilize shop air.
Old Oct 1, 2006 | 08:42 AM
dunewaggon's Avatar
what kind of trans fluid do you use for a 1999 2500 4x4 ? and what kind of filter ?
Old Oct 1, 2006 | 06:16 PM
J BODY's Avatar
Go to the DEALER and get the filter and the newer "re-usable" pan gasket, and the correct ATF +4.
chinook9
Sep 5, 2007 11:43 PM
wildcargo
Jul 22, 2007 03:55 PM
MARKY MARK
Apr 30, 2006 09:47 AM
Bad Ramer Jamer
Jan 14, 2006 10:53 PM
Bad Ramer Jamer
Dec 1, 2005 02:30 PM
