24v's dropping valves
Old Apr 8, 2010 | 03:00 PM
67HotRod's Avatar
My neighbor and very good friend is a diesel mechanic and at his shop are sitting several 24 valve trucks (98.5-02) that have dropped a valve. Most have no mods, but all have had a broken valve spring. Some have some just over 100k miles on them. The latest truck that came in had to sit for a while, cylinder head shop was 3 days behind on 24v heads.
I would think if his shop is seeing these many trucks coming in, there has to be more out there. With my truck over the 200K mark, seriously considering a top end overhaul. Anyone else out there know anything about this?
Thanks!
67HotRod
Old Apr 8, 2010 | 03:09 PM
lovinCTD59's Avatar
I have over 200k on my 24V, and the 24V work truck at the shop has over 420k. No problems. Im not too worried about it.....
Old Apr 8, 2010 | 03:18 PM
67HotRod's Avatar
I have no doubt theres trucks out there with plenty of miles without a problem. Looking to see if theres a pattern with some have an issue dropping a valve. Not trying to start a 'worry' thread, just a fact finding mission right now. Maybe a bad batch of valve springs made it out there?
Thanks!
Old Apr 8, 2010 | 06:17 PM
nitrousn's Avatar
Never seen one or even heard of it as a problem. I think there could be some BS involved.
Old Apr 8, 2010 | 08:22 PM
johnh's Avatar
i worry more about the antifreeze smell i've had for the last seven years...........
Old Apr 8, 2010 | 11:22 PM
lovinCTD59's Avatar
????????? I hate that smell
Old Apr 9, 2010 | 03:43 AM
dozer12216's Avatar
Not heard of a issue with springs. It seems that issues frequentlly come in multiples. One dealer has four of same issue in his shop and another dealer has three of another issue. And noboby else has either issure. Can't explain but have seen this type of problem so many times in past.
Old Apr 9, 2010 | 05:32 AM
Shovelhead's Avatar
Administrator / Scooter Bum
One possible culprit for "dropped valves" could be extended idle periods in COLD weather.
Cummins introduced a 'high idle" into the ECM in the last 5 or so years to combat the problem of carbon deposits accumulating on the valve stems due to low engine temps occuring at cold temps and the low idle speed.
Folks letting the engine run to 'warm up' at idle in frigid temps.
The high idle ramps it up to 1200 rpm in sub freezing temps with a cold start, cold engine, and no throttle input from the driver.
Old Apr 9, 2010 | 09:14 PM
nitrousn's Avatar
While that could be a possibility, I am in a cold climate commont below zero and I do not hear of such issues. I still call bs to the original posters buddys statement.
Old Apr 11, 2010 | 06:36 PM
DodgeRamdiese01's Avatar
Sounds like a FORD guy
Old Apr 12, 2010 | 08:15 AM
RowJ's Avatar
No problems here....and have not ever heard of those kinds of problems anywhere around N.Texas or at the track or on any of the other Dodge web sites I occasionally visit.
Had to replace my head at 160,000 miles, due to firering problems, and no evidence of what you mention. Only high wear area I saw was valve stem guides/seals!
Broken valve springs.... unheard of??
RJ
Old Apr 12, 2010 | 09:14 AM
Junk Man's Avatar
It would be posted on the forums if it were a frequent problem.....VP, steering, cracked dash, track bar, brakes......
Old Apr 12, 2010 | 02:06 PM
Tate's Avatar
Was it dropped valves, or valve seats? The latter is an issue in the some 24v heads, as they went from intregal seats to pressed in seats in the later years of production.
hdcolo
Mar 21, 2015 10:04 AM
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
mostlymetal
Dec 8, 2002 07:29 AM
accordionjohn
Nov 3, 2002 12:30 AM
