24v misfire
24v misfire
My truck recently started acting up. I put a new lift pump on it about 3 months ago. The truck will start, but right after it starts it starts to misfire if I push on the pedal it still misfires. Could it be the Ecm? Or the Vp44?
It may fuel starved, a clogged filter or bad lift pump will do that. The OEM fuel lines are not the greatest and have a tendency to get pin holed. The OEM setup is a mix of steel tubing and semi-rigid plastic tubing. The steel can rust and rot out over time, and the plastic tubing gets brittle and cracks. These fuel systems need 100% liquid fuel in the lines, no air.
I've had both issues on my truck. I've had the lift pump stop running due to a bad electrical connection which fuel starved the engine at anything above idle (fuel pressure was 0). Sputtered a lot and was sluggish.
I recently had a air leak on the suction side of my lift pump which made the engine start missing and sputtering going down the highway (fuel pressure low, around 5 PSI). Didn't idle well and acted erratically, would have power at times, and then start sputtering the next. Would not restart after shutdown. My lift pump pre-filter got loose and was sucking air. Once I found that, and reprimed my fuel lines, it came back to life. That one worried me that the VP44 went out, but the low fuel pressure clued me in towards a fuel delivery issue.
Go over your fuel lines from tank to pumps carefully. Especially if you ever smell diesel fuel near your truck, good indication of a leaky fuel line. I replaced both lines (supply and return) on mine with rubber fuel lines from the tank to the engine.
ECM's generally are good or bad, not often they give weird issues.
FRANKV569
Mar 19, 2005 03:07 PM
IntakeRacing
Dec 10, 2004 08:20 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
