misfire, acceralte problems, dies on idle, won't start now
Old Dec 7, 2004 | 10:58 PM
IntakeRacing's Avatar
misfire, accelerate problems, dies on idle, won't start now
sorta sucks for my first post but i could really use some help! please and thanks...
its a 2001 24 valve and its an auto... only mod is a K&N filter. (lame i know but i just got it)
i came driving back home today and i stopped for lunch with some friends and left the truck idiling cause it was so cold out. (high idle. -30) had lunch, came out truck wasn't running but lights and stuff were all on... it took a couple turns but it started and seemed to be fine.... so i just sorta shrugged it off and carried on my way.. drove fine down the highway..
about 2 hours later i stopped for a **** break and i got out and the truck started sputtering and jumping then stalled on me..
i got it running after about 5-10 mins and a lot of turning it over..... it was misfiring and acting all weird but i was 2 hours from any type of civilization so i reved it up then as the rpms were coming down i slipped her into gear... i got it going but it was still misfiring and sputtering..
after about 30 mins of this it seemed to start to calm down a bit... would still misfire on heavier acceleration.
i got it home and left it idleing while we unloaded the truck.. everything seemed fine.. i noticed the needle was moving a lil bit but not much really.. maybe a 100 rpm tops. drove my friend home.. let it idle there.. drove it back home and then turned it off.. drained the water seperator and stuff then went to start it up and it started fine then stalled out almost right away.. now it WON'T START.. i have it plugged in but its like -30 here.
i did an oil change a week before and drained the water seperator then too....
any help is appreciated... the nearest dodge dealership is 4 hours away.
-Sean
aka Smoke Show (but someone already has it on here)
edit: it has 222,000 km's on it now
Old Dec 7, 2004 | 11:19 PM
clifford's Avatar
Are you using winter fuel?
It could be gelling on you.
Old Dec 7, 2004 | 11:26 PM
cardlock diesel.... same stuff i've always used... i'm assuming so or else a lot of semi's would be packing her in.
Old Dec 7, 2004 | 11:37 PM
ratsun's Avatar
Just a thought?
When you drained the water seperator did you bump the starter a couple of times to cycle the LP so it would fill the canister again? If not you may have pumped some air to the injectors. Try cycling the LP a few times and see if that helps? As far as your poor running prior, its a tough call, you will need to get a gauge on the fuel pressure to the VP44 first and make sure thats ok and if it isnt than you will have to change your lift pump. Good luck and keep us informed
Old Dec 8, 2004 | 01:39 AM
BigBlue's Avatar
See if there are any codes thrown. Turn the key on and off 3 times. On the third ON, leave it on and it will display the codes in the odometer area. If there are any codes, right them down and get back to us. If there is a P0216 code, you need a new injection pump.
Old Dec 8, 2004 | 07:50 AM
therse a p 0500
and a p 1693
Old Dec 8, 2004 | 11:11 AM
mysing418's Avatar
From: 13 miles N.W. of Cleveland, TEXAS in the National Forest
Vehicle Speed Sensor (rear wheel ABS brake) is p0500. The p1693 is a generic code the computer throws when it sees a problem somewhere...
Sometimes you can disconnect the batteries, turn the key to run position for 15-20 mins. to drain the juice off the computer and clear those two codes. Your truck automatic of manual?
A bad lift pump, plugged fuel filter, starving the injector pump for fuel is a bad thing since the vp44 is fuel lubricated and cooled.
You have a fuel pressure gauge?
Old Dec 8, 2004 | 11:58 AM
Lil Dog's Avatar
I would still use fuel conditioner. I do all year and especially in the winter just to make sure I get rid of any moisture and prevent any gelling in the lines to the fuel pump. On the big rigs they have fuel tank heaters and can run at colder temps. We don't have that luxury. For the minor cost of it, throw in a dose of good fuel conditioner (Howes, Stanadyne, Lubetech) and then do as instructed to make sure the unit primes.
I would also take a fuel pressure reading at the fuel canister if you have the equipment to make sure the lift pump is actually pumping. The LP motor can run without any fuel being moved.
J-eh
Old Dec 9, 2004 | 02:23 PM
Wilson's Avatar
On another thread someone was having some of the same symptoms as you and put some of the powerservice 911 in their tank and in the fuel filter canister. It solved their problems and is a cheap way to start here.
Good luck
Old Dec 9, 2004 | 02:44 PM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Yeah that was ME and those WERE my symptoms.......I had howes in mine when it froze up on me.....I ussed diesel 911 made by powerservice (comes in a red jug) and it fixxed itself.....
IT did make for a cold crappy morning though.......after i had to call my boss to come get me in his powerjoke diesel...
Good luck man, just fill the filter and put the rest in the tank.... wait bout 10 minutes and crank her up.
Hope it works, zack
Old Dec 9, 2004 | 02:45 PM
zack_76401's Avatar
PS where are you wilson?
I was up in Morgan when mine froze up but I live in clearfield right next to Hill AFB
Old Dec 9, 2004 | 07:47 PM
dieselhawg's Avatar
It seems funny it would die after it was running for a while,once warmed up it would continue to run,being a 24 valve i would look at the lift pump closely,just my 02.
Old Dec 9, 2004 | 11:23 PM
thumper 549's Avatar
Please do the simple thing(s) 1st. change the fuel filter,, for fun look at the sir filter thingy,,
I could go into all the lingo.......but at the begaining of cold weather (below 32) change the fuel filter then tell us.........
Old Dec 10, 2004 | 09:58 AM
clifford's Avatar
Thumper
The only thing we have to worry about is the rain and our Island doesnt sink.
Old Dec 10, 2004 | 11:58 AM
Wilson's Avatar
Im down in the Highland- American Fork area, 30-40 miles south of Salt Lake. We have been lucky, it hasnt gotten that cold down here. I sure hope it stays that way. Im glad you got your truck up and runnin.
