24 valve question
Old Aug 24, 2006 | 11:45 PM
Marks99's Avatar
Originally Posted by RickCJ
A 24 valve Cummins VP44 is electronic controlled, set to around 1/2 throttle from Dodge. When you add a box and tap the wire you are giving your truck full throttle! The rest of the truck is not up to the power of the engine, the tranny is too weak and the exhaust is too small! You can break things if you run it too hard. The reason a pump dies when you add a box is because the pump wears a groove from 0- 1/2 throttle and when you all the sudden go to full throttle it can bind in the groove and break! And your truck just stops dead. Most don't bind and run good. If it's going to bind it will break ASAP you tap the wire, usually the 1st time you run hard thru the gears. Stay close to home. The pump is no big mystery, as reliable as any other part of your truck. My last truck had over 250k on the oringinal vp. My new truck needed 1 at only 85K. My alternator only lasted to 50k!
Thanks - that's some good info also.
Bought this '99 used few weeks ago, I'm the second owner. All this Banks equipment was installed back when the rig was only about a year old. It has the controller, 4" exhaust, High-Ram intake, BigHead waste gate control etc, the exh. brake, Smartlock trans control, and TC. All seems to work pretty well, but I'm real new to this diesel stuff. The only trouble I'm having is with the M.A.P. sensor voltage, that or the Banks controller is starting to fail ... in which case I'll replace it with an Edge or Smarty ....
Thanks -
CajunDiesel
May 23, 2004 08:49 AM
piperca
33
May 11, 2004 06:40 PM
skinsey
Jul 17, 2003 05:47 PM
1320
May 17, 2003 03:28 PM
phildog
Apr 2, 2003 05:44 AM
